Re: Auto completion in Sirius interpreter does not work [message #1828183 is a reply to message #1828179] |
Wed, 03 June 2020 11:39 |
Avi Shaked Messages: 131 Registered: October 2019 |
Did you check the interpreter view?
I realize my original post was not clear enough.
The interpreter works well when I design Sirius diagrams, for example.
But in the "interpreter view" (typically used below an existing diagram; opened using Windows->Show View->Interpreter), it just does not work when I use "aql:" (only feature, var and service are available).
I don't get any error message (just a beep sound indicating auto-complete did not find anything to complete). And as I mentioned, the aql commands are interpreted well if I write them manually (without auto-complete).
Avi
[Updated on: Wed, 03 June 2020 12:44] Report message to a moderator
Re: Auto completion in Sirius interpreter does not work [message #1828258 is a reply to message #1828183] |
Fri, 05 June 2020 07:11 |
I've created a new Ecore Modeling Project and opened the Interpreter view (make sure the Sirius interpreter is selected, and not the Acceleo one).
The auto-completion seems to work properly after aql: in my environment
Cuuld you try with a simple Ecore Modeling Project to make sure it is not linked with your modeler?
Re: Auto completion in Sirius interpreter does not work [message #1828309 is a reply to message #1828262] |
Sun, 07 June 2020 04:27 |
First of all, thank you Florian for the effort in trying to help me solve this!
The screenshot you provided suggests you are not using the Eclipse Modeling Tools (2020-03) distribution. Am I wrong?
In my Eclipse 2020-03 distribution, there is no "Acceleo interpreter" (only "Sirius" option exists).
[The screenshot you provided is similar to what I see on the Obeo Designer distribution, where auto-completion works perfectly]
Also, as I mentioned in a previous message, the problem is not general: auto-completion does work when I design the Sirius diagrams. It does not work only when I try to use it on existing diagrams as part of the workspace "interpreter" view.
[Updated on: Sun, 07 June 2020 04:27] Report message to a moderator
FUDForum. Page generated in 0.04131 seconds
