Re: EGit not recognising git repositories downloaded using repo tool [message #1828157 is a reply to message #1828152] |
Wed, 03 June 2020 01:32 |
Saravanan Narayanan Messages: 4 Registered: May 2020 |
Hello Thomas Wolf,
Thank you for the sharing.
I have updated the git plugin and again the same issue persists.
When getting cloned from repo init ,
".repo" subdirectory is created and the .git folders for each clone is inside that.
Hence this .repo subdirectory is getting recognised but not the working directory of the clone where source code is present.
Here are the attachments,
1) When I search the working dir, where the source code is available.
2) When I search the .repo alone,
Here we can see the .git inside the " .repo direcotry" is getting recognized, but we need the .git inside the source code folder to be recognized.
Also I could see , the sub directories such as objects, refs, inside .git of source code folder are symlinks pointing to corresponding objects, refs of .repo
Attachment: step3.PNG
(Size: 23.79KB, Downloaded 391 times) -
Attachment: step4.png
(Size: 107.38KB, Downloaded 393 times) -
Attachment: step5.PNG
(Size: 26.62KB, Downloaded 383 times)
[Updated on: Wed, 03 June 2020 14:37] Report message to a moderator
FUDForum. Page generated in 0.03889 seconds
