Re: [CDO] Offline Clone keeps connecting and disconnecting to master [message #1828011 is a reply to message #1827745] |
Fri, 29 May 2020 07:00 |
s st Messages: 4 Registered: June 2019 |
I played a little bit around and created an example on my own which also uses the company example model. They are pretty close to other CDO examples I found online.
Running first the master and then the clone they show the same behavior as described in my first posting.
I then tried to use the weekly build of CDO 5.3.0 including Net4j 4.10.0 and the behavior still stays the same, except that I get the following exception from the master:
[ERROR] NullPointerException
at org.eclipse.net4j.db.DBUtil.serializeTable(DBUtil.java:1217)
at org.eclipse.net4j.db.DBUtil.serializeTable(DBUtil.java:1208)
at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.AbstractHorizontalMappingStrategy.rawExport(AbstractHorizontalMappingStrategy.java:207)
at org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.rawExport(DBStoreAccessor.java:1213)
at org.eclipse.emf.cdo.internal.server.Repository.replicateRaw(Repository.java:1659)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.ReplicateRepositoryRawIndication.responding(ReplicateRepositoryRawIndication.java:70)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.CDOServerIndicationWithMonitoring.responding(CDOServerIndicationWithMonitoring.java:185)
at org.eclipse.net4j.signal.IndicationWithMonitoring.responding(IndicationWithMonitoring.java:93)
at org.eclipse.net4j.signal.IndicationWithResponse.doExtendedOutput(IndicationWithResponse.java:106)
at org.eclipse.net4j.signal.Signal.doOutput(Signal.java:360)
at org.eclipse.net4j.signal.IndicationWithResponse.execute(IndicationWithResponse.java:75)
at org.eclipse.net4j.signal.IndicationWithMonitoring.execute(IndicationWithMonitoring.java:66)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.CDOServerReadIndicationWithMonitoring.execute(CDOServerReadIndicationWithMonitoring.java:36)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:297)
at org.eclipse.net4j.signal.Signal.run(Signal.java:169)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:748)
Am I missing something essential to solve this problem?
Sebastian
[Updated on: Fri, 29 May 2020 08:16] Report message to a moderator
FUDForum. Page generated in 0.03798 seconds
