Problems with makefile when building static library [message #1827666] |
Wed, 20 May 2020 08:47 |
Apurva Patel Messages: 1 Registered: May 2020 |
Hello! I dont have any experience building static libraries so I am facing some problems. I am using open source code and I have to build the project to get the archive file. The project makefile includes a library.cfg file and creates a config.h file. I am using MinGW GCC toolchain and GNU make builder.
Build command: make -f ${workspace_loc:/gateway/makefile}
I added the extra bit after make because I was getting "config.h: No such file or directory".
I added paths to both the main project and include folders for the include directories (under Properties > C/C++ General > Paths and Symbols). I also unchecked the "Generate Makefiles automatically" box (under Project Properties > C/C++ Build) However, I am getting the error "library.cfg: No such file or directory". I do not know what I am missing here. Help will be much appreciated.
FUDForum. Page generated in 0.03750 seconds
