Home » Modeling » TMF (Xtext) » Implementing AbstractLanguageServerTest in Maven project(Language server tests fail with NullpointerException if one chooses Maven for the Xtext project)
Implementing AbstractLanguageServerTest in Maven project [message #1827530] Sun, 17 May 2020 11:46 Go to next message
Hi there
Does someone know what one has to do to get the language server tests running in an Xtext project built with Maven?
In my Xtext project I develop an Eclipse plugin as well as the language server for VS code. Therefore, the Xtext project creation wizzard generates a Maven project (due to Eclipse plugin).
However, the generated Maven build is not able to execute Tests that extend the AbstractLanguageServerTest. I attached the simple "mydsl" example project here, with a language server test added to it.
The tests run perfectly fine in Eclipse, but the Maven build fails with a NullpointerException in the initialize method of the AbstractLanguageServerTest.
Any ideas how the Maven build has to be adapted for LSP tests? Has anyone such an Xtext project where this works?
Thanks for the help!
Stefan
Re: Implementing AbstractLanguageServerTest in Maven project [message #1827533 is a reply to message #1827530] Sun, 17 May 2020 16:05 Go to previous messageGo to next message
for some reason tycho does not seem to call the setup method
this looks like a bug.
but it seems it is fixed in tycho 1.7.0
(dont know which bug exactly it is, maybe mixture of junit and tycho version)
Re: Implementing AbstractLanguageServerTest in Maven project [message #1827545 is a reply to message #1827533] Mon, 18 May 2020 01:56 Go to previous messageGo to next message
Hmmm, I updated the example to tycho 1.7.0 and get the same exception. Where you able to fix it in the sample project? And if yes: what exactly have you changed?
Re: Implementing AbstractLanguageServerTest in Maven project [message #1827546 is a reply to message #1827545] Mon, 18 May 2020 02:13 Go to previous messageGo to next message
Is there a workaround maybe? Because it would be a bummer if we cannot get this working quickly... kind of show-stopper for the language server in our project :-/
Re: Implementing AbstractLanguageServerTest in Maven project [message #1827548 is a reply to message #1827546] Mon, 18 May 2020 02:57 Go to previous messageGo to next message
no didnt change anything.
Re: Implementing AbstractLanguageServerTest in Maven project [message #1827549 is a reply to message #1827548] Mon, 18 May 2020 03:02 Go to previous messageGo to next message
So, you say changing the tycho version in the parent pom from 1.6.0 to 1.7.0 fixes the problem for you?
Re: Implementing AbstractLanguageServerTest in Maven project [message #1827550 is a reply to message #1827549] Mon, 18 May 2020 03:13 Go to previous messageGo to next message
hmm. on my machine i saw it green. could also be a problem with stuff in the dependencies/target
can you ask on tycho-user mailing list then? this should be reproducible in an non Xtext context too.
Re: Implementing AbstractLanguageServerTest in Maven project [message #1827552 is a reply to message #1827550] Mon, 18 May 2020 03:27 Go to previous messageGo to next message
you can also deug the setup code with
mvn clean install -DdebugPort=8000
and then do connect with remote debugger
Re: Implementing AbstractLanguageServerTest in Maven project [message #1827553 is a reply to message #1827550] Mon, 18 May 2020 03:27 Go to previous messageGo to next message
Okay. Nothing to do with the AbstractLanguageServerTest then?
Which setup method were you talking about? (the one tycho should call)
Re: Implementing AbstractLanguageServerTest in Maven project [message #1827555 is a reply to message #1827552] Mon, 18 May 2020 03:52 Go to previous messageGo to next message
hand another look.
it looks like the service loader stuff in ResourceServiceProviderServiceLoader
seems to have problems with tycho or/and java 11
(org.eclipse.tycho.surefire.osgibooter.CombinedClassLoader)
[Updated on: Mon, 18 May 2020 03:58] by Moderator
Re: Implementing AbstractLanguageServerTest in Maven project [message #1827558 is a reply to message #1827550] Mon, 18 May 2020 04:08 Go to previous messageGo to next message
package org.xtext.example.mydsl.tests;
import java.util.ServiceLoader;
import org.eclipse.xtext.ISetup;
import org.eclipse.xtext.xbase.lib.IterableExtensions;
import org.junit.Assert;
import org.junit.jupiter.api.BeforeEach;
import org.junit.jupiter.api.Test;
public class DemoTest {
@BeforeEach
public void setup() {
ServiceLoader<ISetup> sl = ServiceLoader.<ISetup>load(ISetup.class);
Assert.assertFalse(IterableExtensions.isEmpty(sl));
@Test
public void test02_openFile() {
shows the problem in a simply test too.
=> this seems to be a tycho bug
please ask at tycho-user mailing list
Re: Implementing AbstractLanguageServerTest in Maven project [message #1827559 is a reply to message #1827558] Mon, 18 May 2020 04:25 Go to previous messageGo to next message
What a pity :(
Thanks however for analyzing the problem. I asked at tycho-user mailing list now.
Re: Implementing AbstractLanguageServerTest in Maven project [message #1827562 is a reply to message #1827559] Mon, 18 May 2020 05:52 Go to previous messageGo to next message
hmmm. even if i configure the maven-surefire-plugin the setup method does not seem to be called.
no idea why
Re: Implementing AbstractLanguageServerTest in Maven project [message #1827563 is a reply to message #1827562] Mon, 18 May 2020 06:09 Go to previous messageGo to next message
looks like this one works
<project xmlns="http://maven.apache.org/POM/4.0.0"
xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/xsd/maven-4.0.0.xsd">
<modelVersion>4.0.0</modelVersion>
<parent>
<groupId>org.xtext.example.mydsl2</groupId>
<artifactId>org.xtext.example.mydsl2.parent</artifactId>
<version>1.0.0-SNAPSHOT</version>
</parent>
<artifactId>org.xtext.example.mydsl2.tests</artifactId>
<packaging>eclipse-plugin</packaging>
<build>
<plugins>
<plugin>
<groupId>org.eclipse.xtend</groupId>
<artifactId>xtend-maven-plugin</artifactId>
</plugin>
<plugin>
<groupId>org.apache.maven.plugins</groupId>
<artifactId>maven-surefire-plugin</artifactId>
<version>2.22.1</version>
<executions>
<execution>
<id>test</id>
<phase>test</phase>
<configuration>
<testSourceDirectory>src,src-gen,xtend-gen,testlang-src,testlang-src-gen</testSourceDirectory>
<testClassesDirectory>target/classes</testClassesDirectory>
<failIfNoTests>true</failIfNoTests>
<includes>
<include>**/*Test.java</include>
</includes>
</configuration>
<goals>
<goal>test</goal>
</goals>
</execution>
</executions>
<dependencies>
<dependency>
<groupId>org.apache.maven.surefire</groupId>
<artifactId>surefire-junit47</artifactId>
</dependency>
</dependencies>
</plugin>
</plugins>
</build>
</project>
a similar adaption for junit5 should work too
Re: Implementing AbstractLanguageServerTest in Maven project [message #1827571 is a reply to message #1827563] Mon, 18 May 2020 09:59 Go to previous message
Thanks for your help Christian!
Previous Topic:Saving/opening files is blocked while code generation
Next Topic:Understanding why my Xtend editor is slow
Current Time: Sun Jun 15 08:31:24 EDT 2025
Powered by FUDForum. Page generated in 0.81215 seconds
