Home » Newcomers » Newcomers » Conversion from oxygen to jee-2020-03 and from java 8 to java 14(Unable to retrieve the bundle from the URI: ....)
Conversion from oxygen to jee-2020-03 and from java 8 to java 14 [message #1827528] Sun, 17 May 2020 15:23 Go to next message
Roland Lensink is currently offline Roland LensinkFriend
I made a conversion from Eclipse Oxygen to Jee-2020-03 and from Java 8 to Java 14.
I repaired some errors of this conversion and some deprecated methods, classes or interfaces.
I don't know what to do ...
Re: Conversion from oxygen to jee-2020-03 and from java 8 to java 14 [message #1827531 is a reply to message #1827528] Sun, 17 May 2020 16:21 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin DahyabhaiFriend
The Code Recommenders project has been terminated. You can go ahead and uninstall any features with that name.
_
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: Conversion from oxygen to jee-2020-03 and from java 8 to java 14 [message #1827534 is a reply to message #1827531] Sun, 17 May 2020 21:16 Go to previous messageGo to next message
I never heard from Code Recommenders, where do I find them ...
In my source code, annotations, jar files ???
Re: Conversion from oxygen to jee-2020-03 and from java 8 to java 14 [message #1827539 is a reply to message #1827534] Mon, 18 May 2020 02:12 Go to previous messageGo to next message
Check your About dialog's list of installed features.
_
Nitin Dahyabhai
Re: Conversion from oxygen to jee-2020-03 and from java 8 to java 14 [message #1827601 is a reply to message #1827539] Tue, 19 May 2020 07:59 Go to previous messageGo to next message
I don't understand. When I look in About dialog list under plug-ins ... there is a plug-in 'org.eclipse.e4.ui.workbench' ... but eclipse says, I cannot find it ...
Re: Conversion from oxygen to jee-2020-03 and from java 8 to java 14 [message #1827602 is a reply to message #1827601] Tue, 19 May 2020 08:14 Go to previous messageGo to next message
Click on the Installation Details button.
_
Nitin Dahyabhai
Re: Conversion from oxygen to jee-2020-03 and from java 8 to java 14 [message #1827629 is a reply to message #1827602] Tue, 19 May 2020 15:50 Go to previous messageGo to next message
Please, try to be clear!
When I look at the installation details, tab plug-ins, there is plug-in Id 'org. eclipse.e4.ui.workbench' ....
So what do I have to do now ??????
Re: Conversion from oxygen to jee-2020-03 and from java 8 to java 14 [message #1827661 is a reply to message #1827629] Wed, 20 May 2020 07:29 Go to previous messageGo to next message
It's maybe unhelpful, but I would personally create a new installation from scratch. Also create a new workspace. Then use File -> Import -> General -> Existing Project into Workspace to copy the projects from the old workspace into the new one; be sure to check the dialog that you actually copy the projects, not just link to them.
Ed Merks
Re: Conversion from oxygen to jee-2020-03 and from java 8 to java 14 [message #1827825 is a reply to message #1827661] Mon, 25 May 2020 07:35 Go to previous message
tomas platz is currently offline tomas platzFriend
Ed Merks wrote on Wed, 20 May 2020 07:29
Hi there. I had the same problem and now it works, thanks a lot.
Work hard have fun
Essays for sale
Previous Topic:The import javafx cannot be resolved
Next Topic:Tiny icons with eclipse oxygen on HIDPI resolution (3840x2160) with UBUNTU 16.04
Current Time: Tue Apr 16 13:56:40 GMT 2024
Powered by FUDForum. Page generated in 0.41217 seconds
