Home » Modeling » TMF (Xtext) » Use IChangeSerializer for refactoring that changes multiple Xtext files(Problem with IChangeSerializer, if refactoring change multiple resources)
Use IChangeSerializer for refactoring that changes multiple Xtext files [message #1827408] Thu, 14 May 2020 08:21 Go to next message
Stefan Kapferer is currently offline Stefan KapfererFriend
Hi there
I have a question regarding the ChangeSerializer that I use to implement a refactoring for my Xtext language (Xtext LSP + VS code IDE).
My language uses imports, which means a user is able to reference objects in other files. Therefore, my refactoring potentially changes multiple files (Xtext resources).
In my language server I implement the refactoring as a command that creates a WorkspaceEdit.
I construct the WorkspaceEdit as follows:
private WorkspaceEdit createWorkspaceEdit(ILanguageServerAccess access, URI resourceURI, Document document, IChangeSerializer.IModification<Resource> mod) {
  ResourceSet rs = access.newLiveScopeResourceSet(resourceURI);
  Resource copy = rs.getResource(resourceURI, true);
  IChangeSerializer serializer = serializerProvider.get();
  EcoreUtil.resolveAll(copy); // resolve all imported resources (ensures that imported files are part of the ResourceSet)
  serializer.addModification(copy, mod);
  List<IEmfResourceChange> documentchanges = new ArrayList<>();
  serializer.applyModifications(CollectionBasedAcceptor.of(documentchanges));
  WorkspaceEdit workspaceEdit = new WorkspaceEdit();
  for (ITextDocumentChange documentchange : Iterables.filter(documentchanges, ITextDocumentChange.class)) {
    List<TextEdit> edits = ListExtensions.map(documentchange.getReplacements(), (ITextReplacement replacement) -> {
      TextEdit textEdit = new TextEdit();
      // I create the textEdit here
      return textEdit;
    workspaceEdit.getChanges().put(documentchange.getNewURI().toString(), edits);
  return workspaceEdit;
My problem: everything works fine as long as my modification (IChangeSerializer.IModification) only changes objects in a single file. If the modification changes objects that are spread accross multiple files, I get the following exception when calling serializer.applyModifications:
org.eclipse.emf.common.util.BasicEList$BasicIndexOutOfBoundsException: index=1, size=1
	at org.eclipse.emf.common.util.BasicEList.get(BasicEList.java:346)
	at org.eclipse.xtext.ide.serializer.impl.ReferenceUpdater.createUpdatableReference(ReferenceUpdater.java:90)
	at org.eclipse.xtext.ide.serializer.impl.ReferenceUpdater.updateAllReferences(ReferenceUpdater.java:215)
	at org.eclipse.xtext.ide.serializer.impl.ReferenceUpdater.update(ReferenceUpdater.java:203)
	at org.eclipse.xtext.ide.serializer.impl.RecordingXtextResourceUpdater.applyChange(RecordingXtextResourceUpdater.java:70)
	at org.eclipse.xtext.ide.serializer.impl.ChangeSerializer.endRecordChanges(ChangeSerializer.java:191)
	at org.eclipse.xtext.ide.serializer.impl.ChangeSerializer.applyModifications(ChangeSerializer.java:113)
Any ideas what I am doing wrong? Do I somehow have to register all affected resources manually?
Re: Use IChangeSerializer for refactoring that changes multiple Xtext files [message #1827409 is a reply to message #1827408] Thu, 14 May 2020 08:25 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
what i dont see:
do you put all changes to one file here
can you provide a reproducing unit test + hw dsl
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
[Updated on: Thu, 14 May 2020 08:25]
Report message to a moderator
Re: Use IChangeSerializer for refactoring that changes multiple Xtext files [message #1827410 is a reply to message #1827409] Thu, 14 May 2020 08:33 Go to previous messageGo to next message
p.s. which Xtext version do you use?
Re: Use IChangeSerializer for refactoring that changes multiple Xtext files [message #1827412 is a reply to message #1827409] Thu, 14 May 2020 08:33 Go to previous messageGo to next message
Actually the code at the end of the method that constructs the WorkspaceEdit is never reached, as the following line already throws the exception:
I'm not yet sure if my code at the end is correct, but I never came that far :)
I hoped I am doing something "obviously wrong" before calling the ChangeSerializer.
Given your answer I assume this is not the case... :) I have to prepare such a unit test...
Re: Use IChangeSerializer for refactoring that changes multiple Xtext files [message #1827414 is a reply to message #1827412] Thu, 14 May 2020 08:34 Go to previous messageGo to next message
I use Xtext 2.20.0.
Re: Use IChangeSerializer for refactoring that changes multiple Xtext files [message #1827415 is a reply to message #1827414] Thu, 14 May 2020 08:44 Go to previous messageGo to next message
could be also a bug in the reference updater.
=> minimal reproducing example would be nice.
Re: Use IChangeSerializer for refactoring that changes multiple Xtext files [message #1827435 is a reply to message #1827415] Thu, 14 May 2020 12:19 Go to previous messageGo to next message
Seems to be a bug, from my perspective.
Problem update:
It has nothing to do with the fact that I use multiple files. I can now reproduce it with a single DSL file as well.
The problem occurs because my modification deletes EObjects from the model which are referenced in the original state.
Although I also delete the reference from the corresponding reference list, the exception occurs.
As I see it, there is a problem with this logic in the ReferenceUpdater (createUpdatableReference method):
List<?> targets = (List<?>) value;
int i = current.getIndexInContainingFeature();
EObject t = (EObject) targets.get(i);
if (t != null && !t.eIsProxy()) {
  return new UpdatableReference(owner, ref, i, t, crossRef, current);
And the problem with this code is that the index i is calculated based on the original model state. The index is correct for the state before the modification.
But the targets list corresponds to the state after the modification and does no longer contain the deleted reference.
My modification removes an EObject by calling EcoreUtil2.delete(object), which already cleans the references and removes it from the list.
Is it possible that the ReferenceUpdater cannot handle modifications which delete model parts?
Or formulated in another way: Does the ReferenceUpdater respect the fact that some references may have been deleted during a modification? It seems to me that it does not handle this case.
Re: Use IChangeSerializer for refactoring that changes multiple Xtext files [message #1827441 is a reply to message #1827435] Thu, 14 May 2020 14:31 Go to previous messageGo to next message
yes for sure. can you please create a nug with steps / example at github.com/eclipse/xtext-core
Re: Use IChangeSerializer for refactoring that changes multiple Xtext files [message #1827488 is a reply to message #1827441] Fri, 15 May 2020 15:28 Go to previous messageGo to next message
Hi Christian
Sure, I will create an issue there...
I also created an example with a unit test to reproduce the issue in your language server example project. You can find it here:
https://github.com/stefan-ka/xtext-languageserver-example
And here is the unit test: https://github.com/stefan-ka/xtext-languageserver-example/blob/master/org.xtext.example.mydsl.tests/src/org/xtext/example/mydsl/ide/tests/CommandServiceTest.xtend
The example is simple: I created a command which removes the "Hello Xtext!" greeting in the first line.
The first test method illustrates the case where the modification works, as there is no reference to the "Xtext" greeting.
The second test method throws the exception above, as there is a second greeting that references the first one (the modification removes the reference).
If you run the mentioned test you will see that the first method passes and the second method throws the exception.
Another question:
To test this, I let the command return the WorkspaceEdit. However, returning the edit is not necessary, as I call access.getLanguageClient().applyEdit() to apply the edit. But I don't know how to test this with the provided test tools. Is there a way to access the WorkspaceEdit that is passed to access.getLanguageClient().applyEdit() in the unit test?
Re: Use IChangeSerializer for refactoring that changes multiple Xtext files [message #1827489 is a reply to message #1827488] Fri, 15 May 2020 15:56 Go to previous message
I created the issue here:
https://github.com/eclipse/xtext-core/issues/1494
Stefan
Previous Topic:Accessing resources in standalone mode
Next Topic:Saving/opening files is blocked while code generation
Current Time: Mon May 17 19:26:57 GMT 2021
Powered by FUDForum. Page generated in 0.01950 seconds
