Workbench restarts during createAndRunWorkench method call during a button click of a popup winndow [message #1827353] |
Wed, 13 May 2020 15:57 |
utpal patra Messages: 2 Registered: May 2020 |
We've an eclipse based tool. The below error comes when we click a button of a popup/child window.
!MESSAGE Unhandled event loop exception
!STACK 0
org.eclipse.swt.SWTException: Widget is disposed
at org.eclipse.swt.SWT.error(SWT.java:4533)
at org.eclipse.swt.SWT.error(SWT.java:4448)
at org.eclipse.swt.SWT.error(SWT.java:4419)
at org.eclipse.swt.widgets.Widget.error(Widget.java:482)
at org.eclipse.swt.widgets.Widget.checkWidget(Widget.java:354)
at org.eclipse.swt.widgets.Label.setImage(Label.java:357)
at org.eclipse.jface.dialogs.TitleAreaDialog.setTitleImage(TitleAreaDialog.java:674)
at org.eclipse.jface.wizard.WizardDialog.hardClose(WizardDialog.java:852)
at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDialog.java:798)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:423)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:618)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:249)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4418)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1079)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4236)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3824)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:818)
at org.eclipse.jface.window.Window.open(Window.java:794)
at com.ibm.ecm.configmgr.app.nexus.handlers.ProfileOpenHandler.execute(ProfileOpenHandler.java:166)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:295)
at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:90)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:90)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:55)
at java.lang.reflect.Method.invoke(Method.java:508)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:55)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:282)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:264)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:132)
at org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:152)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:494)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:488)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:210)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.executeItem(HandledContributionItem.java:433)
at org.eclipse.e4.ui.workbench.renderers.swt.AbstractContributionItem.handleWidgetSelection(AbstractContributionItem.java:454)
at org.eclipse.e4.ui.workbench.renderers.swt.AbstractContributionItem$3.handleEvent(AbstractContributionItem.java:482)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1121)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1022)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:150)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:693)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:610)
at com.ibm.ecm.configmgr.app.nexus.rcp.Application.start(Application.java:89)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610)
at org.eclipse.equinox.launcher.Main.run(Main.java:1519)
at org.eclipse.equinox.launcher.Main.main(Main.java:1492)
!SESSION 2020-05-13 08:28:23.221 -----------------------------------------------
eclipse.buildId=unknown
java.fullversion=8.0.5.40 - pwa6480sr5fp40-20190807_01(SR5 FP40)
JRE 1.8.0 Windows Server 2016 amd64-64-Bit Compressed References 20190802_424001 (JIT enabled, AOT enabled)
OpenJ9 - 106f6ce
OMR - fe07f6f
IBM - af2a365
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Framework arguments: -product com.ibm.ecm.configmgr.app.nexus.product gui
Command-line arguments: -product com.ibm.ecm.configmgr.app.nexus.product -data C:\WorkSpaces\ConfigTool305176/../runtime-com.ibm.ecm.configmgr.app.nexus.product -dev file:C:/WorkSpaces/ConfigTool305176/.metadata/.plugins/org.eclipse.pde.core/com.ibm.ecm.configmgr.app.nexus.product/dev.properties -os win32 -ws win32 -arch x86_64 -consoleLog gui
The above is coming in the below code:
Display display = PlatformUI.createDisplay();
createAppColors(display);
try {
int returnCode = PlatformUI.createAndRunWorkbench(display, new ApplicationWorkbenchAdvisor());
if (returnCode == PlatformUI.RETURN_RESTART)
return IApplication.EXIT_RESTART;
else
return IApplication.EXIT_OK;
} finally {
display.dispose();
In config.ini we've
osgi.bundles=org.eclipse.equinox.common@2:start,org.eclipse.update.configurator@3:start,org.eclipse.core.runtime@3:start,org.eclipse.equinox.ds@3:start,eclipse.equinox.event@3:start
osgi.bundles.defaultStartLevel=4
Could anybody please help.... Thanks in advance....
FUDForum. Page generated in 0.03045 seconds
