Home » Polarsys » Capella General » Requirement viewpoint in Capella(Requirement viewpoint )
Requirement viewpoint in Capella [message #1826908] Mon, 04 May 2020 12:32 Go to next message
Behrang MORADI is currently offline Behrang MORADIFriend
I installed requirement viewpoint and activated the view "Capella Requirement" from the viewpoint manager.
Capella Version: 1.4.0
Build id: 201911211736
But, I cannot see the context menu for importing the reqif. ???
Best regards
Behrang
Re: Requirement viewpoint in Capella [message #1826930 is a reply to message #1826908] Mon, 04 May 2020 18:23 Go to previous messageGo to next message
Stephane LACRAMPE is currently offline Stephane LACRAMPEFriend
Works for me.
Are you right-clicking on an Architecture element, like the "Operational Analysis" folder?
Is your Viewpoint shown as active in the Viewpoint Manager?
What is the Requirement Viewpoint version you installed?
All the best,
Stephane
Stephane LACRAMPE
Obeo Canada
Re: Requirement viewpoint in Capella [message #1827061 is a reply to message #1826930] Wed, 06 May 2020 14:03 Go to previous messageGo to next message
Hello Stephane,
Thank you for responding,
I updated the Requinquent Viewpoint file and it works.
I have another question about the management and traceability of requirements (Requirement Viewpoint) in differents layers of Capella (Operational, System, Logical, Phisical).
For that, can we define the requirements at the Operational layer and then transfer to the system layer, logical, physical level?
Or, do we have to define requirements in each layer and ferine that?
I thank you in advance.
Best regards
Behrang
Re: Requirement viewpoint in Capella [message #1827065 is a reply to message #1827061] Wed, 06 May 2020 14:23 Go to previous messageGo to next message
In principle, one is supposed to keep each Capella engineering level independant one from each other,
But I will let other people answer your question specifically on Requirements.
Stephane
Stephane LACRAMPE
Obeo Canada
Re: Requirement viewpoint in Capella [message #1827066 is a reply to message #1827065] Wed, 06 May 2020 14:37 Go to previous message
Thanks a lot
Behrang
Previous Topic:Change in Transition of Logical Components to Physical Architecture v1.3.1 vs v1.4.0
Next Topic:Technical Documentation Linked
Current Time: Sun Nov 29 14:27:57 GMT 2020
Powered by FUDForum. Page generated in 0.02737 seconds
