Home » Modeling » M2T (model-to-text transformation) » how to read EAnnotations separately in for loop?
how to read EAnnotations separately in for loop? [message #1826574] Mon, 27 April 2020 07:03 Go to next message
Hi!
I want to separate the "key" attribute and its "value" in for loop but its printing all keys & values together.can any1 help?
Code:
[for (c: EClass | anEPackage.eAllContents())]
Class Name = [c.name/]
[for (ea: EAnnotation | c.eAllContents())]Annotation Type = [ea.source/]
Key Type = "[ea.details.key/]"
Value Type = "[ea.details.value/]"
[/for]
[/for]
output:
Class Name = Node
Annotation Type = gmf.node
Key Type = "labelborder.colorborder.styleborder.widthfigure"
Value Type = "name0,0,255solid3ellipse"
Reagrds,
fatima
Re: how to read EAnnotations separately in for loop? [message #1826582 is a reply to message #1826574] Mon, 27 April 2020 09:39 Go to previous messageGo to next message
If you read the metamodel you will see that details is a collection and so details.key is a shortform for details->collect(key).
Ed Willink
Re: how to read EAnnotations separately in for loop? [message #1826586 is a reply to message #1826582] Mon, 27 April 2020 10:16 Go to previous messageGo to next message
i want to store them one by one in separate variables or arraylist(in pair of key & value). But i dont know how to do this in Acceleo?
fatima
Re: how to read EAnnotations separately in for loop? [message #1826611 is a reply to message #1826586] Mon, 27 April 2020 14:08 Go to previous messageGo to next message
You are still very vague, but if you look at the print out that you orially complained about, it was the print out of all the keys in a single collection , and then all the values in another collection. The only purpose of the for loop is to turn the one-dimensional execution of the implicit collect into a two dimensional iteration that does everything N times more often than you want. Scrap the for loop.
Ed Willink
Re: how to read EAnnotations separately in for loop? [message #1826727 is a reply to message #1826611] Wed, 29 April 2020 10:43 Go to previous messageGo to next message
hi! from the following code if i want to access any specific key and its corresponding value then how to get it :( :(
(e.g; if key = "width" get the value= "2").
<eAnnotations source="gmf.link">
<details key="label" value="name"/>
<details key="source" value="source"/>
<details key="target" value="target"/>
<details key="style" value="dash"/>
<details key="width" value="2"/>
<details key="color" value="255,255,0"/>
<details key="source.decoration" value="filledsquare"/>
</eAnnotations>
fatima
Re: how to read EAnnotations separately in for loop? [message #1826732 is a reply to message #1826727] Wed, 29 April 2020 11:16 Go to previous messageGo to next message
HI
The time has clearly come for you to read the OCL book.
https://www.amazon.co.uk/Object-Constraint-Language-Addison-Wesley-Technology/dp/0321179366
Ed Willink
Re: how to read EAnnotations separately in for loop? [message #1826885 is a reply to message #1826732] Sun, 03 May 2020 22:41 Go to previous messageGo to next message
Hi!
Thanks Willink ! i have ordered the book let see when it will reach!
The problem i was facing , i got the idea to solve it :),hence it solved.
Just few small questions :
1* how can i use OR operator in Acceleo e.g, in it [if ea.details.value->at(2) = 'rounded ' || 'rectangle']
2* is there any function in Acceleo which can convert decimal to hex ?
3* can i define use functions and then use them in Acceleo?
Many Thanks!
fatima
Re: how to read EAnnotations separately in for loop? [message #1826895 is a reply to message #1826885] Mon, 04 May 2020 02:54 Go to previous messageGo to next message
Sorry. A forum is for help on a problem. It is not a documentation query service.
Ed Willink
Re: how to read EAnnotations separately in for loop? [message #1826897 is a reply to message #1826895] Mon, 04 May 2020 04:41 Go to previous message
ok!
Previous Topic:How to read the graphical notations?
Next Topic:How can I get a class which is inherited from another class in acceleo
Current Time: Sun Nov 09 11:28:08 EST 2025
Powered by FUDForum. Page generated in 0.05318 seconds
