java.util.logging is not accessible [message #1826486] |
Sat, 25 April 2020 17:56 |
james rollinson Messages: 2 Registered: April 2020 |
I am a cobol mainframe developer, now following the Feb 2020 ibm java tutorial using eclipse & adoptopenjdk.
in unit 5 .....developer.ibm.com/tutorials/j-introtojava2/ the sample codes
import java.util.logging.Logger;
Logger l = Logger.getLogger(getClass().getName());
and I get this message java.util.logging is not accessible.
my PATH is PATH=C:\Program Files\AdoptOpenJDK\jdk-11.0.7.10-openj9\bin;
eclipse version is Eclipse IDE for Java Developers
Version: 2020-03 (4.15.0)
Build id: 20200313-1211
Question: why can't the java compiler find this logger routine?
The build path for this class has the library JRE system library [javaSE-11] with e.g. java.desktop, java.naming but no java.logging .
Help !
26th April
I also tried compiling from the command line, similar problem I think:
C:\Users\jroll\eclipse-workspace\Hello World\src\com\makotojava\intro>javac Person.java
Person.java:5: error: cannot find symbol
Logger l = Logger.getlogger(Person.class.getName());
symbol: class Logger
symbol: variable Logger
2 errors
C:\Users\jroll\eclipse-workspace\Hello World\src\com\makotojava\intro>java -version
openjdk version "11.0.7" 2020-04-14
OpenJDK Runtime Environment AdoptOpenJDK (build 11.0.7+10)
Eclipse OpenJ9 VM AdoptOpenJDK (build openj9-0.20.0, JRE 11 Windows 10 amd64-64-Bit Compressed References 20200416_544 (JIT enabled, AOT enabled)
OpenJ9 - 05fa2d361
OMR - d4365f371
JCL - 838028fc9d based on jdk-11.0.7+10)
[Updated on: Sun, 26 April 2020 08:09] Report message to a moderator
FUDForum. Page generated in 0.08305 seconds
