Home » Polarsys » Capella workbench » OAIB Issue(Root Operational Activities missing in transfer dialog)
OAIB Issue [message #1826470] Sat, 25 April 2020 12:29 Go to next message
Marius Tillmann is currently offline Marius TillmannFriend
Hello all!
I started my first MBSE project with Capella. I´m currently in the Operational Analysis phase. I´m at the point where I want to create my OAIB diagram which is helpful for the definition of operational processes.
I wanted to insert the operational activities via the transfer dialog. Unfortunately the software shows not all OAs in the window. What is wrong here? Some links missing? In case I make drag&drop from model tree everything works fine.
Attached please find a picture of the issue.
Thanks in advance for your help!
Re: OAIB Issue [message #1826476 is a reply to message #1826470] Sat, 25 April 2020 15:35 Go to previous messageGo to next message
Navas Juan is currently offline Navas JuanFriend
Member
Hello
I'm guessing that the "transfer" dialog you are talking about is in fact the tool in the Palette of OAIB diagrams called Operational Activities?
If it is the case, I wasn't able to reproduce your issue, it works fine in my Capella 1.4.
Re: OAIB Issue [message #1826483 is a reply to message #1826476] Sat, 25 April 2020 16:55 Go to previous messageGo to next message
Stephane LACRAMPE is currently offline Stephane LACRAMPEFriend
Juan,
I am reproducing it with Capella 1.4.0 on my end. I created a new OAIB diagram at the Operational Activities root of the IFE example, and when trying to insert them, only a subset is showing.
I did the same on Capella 1.3.1 and they all showed up.
Stephane
Stephane LACRAMPE
Obeo Canada
Re: OAIB Issue [message #1826494 is a reply to message #1826483] Sat, 25 April 2020 21:49 Go to previous messageGo to next message
Hi Stephane,
thanks for your response. Does it mean this issue is linked to Vers. 1.4.0? Or in other words: I did not make a miste? :-)
Marius
Re: OAIB Issue [message #1826498 is a reply to message #1826494] Sat, 25 April 2020 22:26 Go to previous messageGo to next message
Hi Marius,
Well, I am not 100% sure as Juan said it was working for him, but either I am doing something wrong, either it is an issue with version 1.4.0.
You can try with version 1.3.1 on your end and check if it is working.
Stephane
Stephane LACRAMPE
Obeo Canada
Re: OAIB Issue [message #1826560 is a reply to message #1826498] Mon, 27 April 2020 06:55 Go to previous message
Philippe Dul is currently offline Philippe DulFriend
I have created an issue.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=562503
Previous Topic:Were missions removed?
Next Topic:Operation Activity Interaction
Current Time: Fri Dec 13 15:41:07 GMT 2024
Powered by FUDForum. Page generated in 0.03392 seconds
