Home » Modeling » TMF (Xtext) » Parsing XML
Parsing XML [message #1826154] Mon, 20 April 2020 11:39 Go to next message
Francisco Martínez Lasaca is currently offline Francisco Martínez LasacaFriend
I have a simple meta-model for a concrete XML subset. I have to implement a simple description tag which includes arbitrary text inside.
This is a simple example:
<?xml version="1.0"?>
<package format="3">
  <name>my_name</name>
  <version>1.0.0</version>
  <description>This is the description</description>
I have created this EMF class
class DescriptionTag extends Tag {
  attr String[1] description;
along with this Xtext implementation
DescriptionTag returns DescriptionTag:
	"<" 'description' ">" description=STRING "<" "/" 'description' ">";
the problem is that STRINGs in Xtext are quoted, and I would like to get rid of those (bloody) quotes.
This is an example of a valid (yet not desired) parsed excerpt of a file:
  <description>"This is the description"</description>
I have tried redefining the grammar (that STRING comes from org.eclipse.xtext.common.Terminals).
Any idea?
Re: Parsing XML [message #1826178 is a reply to message #1826154] Mon, 20 April 2020 16:34 Go to previous messageGo to next message
Tamas Miklossy is currently offline Tamas MiklossyFriend
Hello Francisco!
For parsing XML with Xtext, you can take a look at the Eclipse GEF project.
The GEF DOT editor is an Xtext-based editor and it is capable of parsing Graphviz HTML-Like labels.
For further information you can study the following blog posts and videos:
- Graphical Editing Framework (GEF) 5.0.0 Release
- Editing Graphviz *.dot files with the GEF DOT Editor
- GEF 5.0.0 - From a User's Perspective (at 09:32)
- Eclipse GEF DOT - Graphviz authoring environment in Eclipse (at 21:03)
The corrsponding Xtext grammar files are available under:
- Dot.xtext
- DotHtmlLabel.xtext
Hope that helps,
Tamás
[Updated on: Mon, 20 April 2020 16:44]
Report message to a moderator
Re: Parsing XML [message #1826192 is a reply to message #1826178] Mon, 20 April 2020 19:42 Go to previous messageGo to next message
Do you really want to 'parse' XML? The problem is very well solved by the SAXParser and integrated by EMF.
If you want more insight into the XML structure you might consider the /org.eclipse.qvtd.xml/model/XMLmodel.ecore that forms parts of the QVTd distribution. It creates a usable Ecore model instance of the XML, using its own overload of the SAXParser.
If you really really want to parse XML, I can point you at some code that produces a custom Xtext / LPG parser from the Ecore metamodel of your XML. I have not progressed it much since while such an optimized parser is quite a bit faster, in practice it isn't since the optimized parser is custom and so needs to warm up the JVM whereas the slower EMF parser is probably already warm from previous usage. The custom parser will only really be an unequivocal win once generated as C code.
Ed Willink
Re: Parsing XML [message #1827906 is a reply to message #1826154] Tue, 26 May 2020 16:42 Go to previous messageGo to next message
Hi all,
Sorry for answering back so late.
Thanks for all your resources.
I am not worried about parsing entire XML files (I have a really concrete subset of tags I'm working with), but getting rid of the quotes I mention.
Thanks.
[Updated on: Tue, 26 May 2020 16:57]
Re: Parsing XML [message #1827909 is a reply to message #1827906] Tue, 26 May 2020 17:54 Go to previous message
HI
Well going back to your original comment:
'simple' and 'arbitrary' are a contradiction.
If you need arbitrary text then you have to have an escape mechanism to distinguish awkward characters with the arbitrary text from the same characters as subsequent text. The double quotes and backslashing is one such escape mechanism. Of course if you really like XML, you could use CDATA instead. That may provoke a stronger expletive.
Ed Willink
Previous Topic:Synchronize with resources
Next Topic:How to infer an annotation with a key-value pair
Current Time: Sat Jul 24 21:28:26 GMT 2021
Powered by FUDForum. Page generated in 0.01711 seconds
