Home » Eclipse Projects » Eclipse Titan » RDF-related encodings in Titan
RDF-related encodings in Titan [message #1824397] Tue, 14 April 2020 17:49 Go to next message
Sascha Hackel is currently offline Sascha HackelFriend
I'd like to receive JSON-LD encoded messages as I work with linked data (RDF) at the moment.
Unfortunately, I couldn't find any RDF-related encodings (e.g. turtle or JSON-LD).
So my first simple try was to use the JSON encoding built into Titan, but of course, due to the invalid token "@" that is used in JSON-LD for certain keywords, the decoding failed.
Is there any straightforward way to make Titan handle Turtle or JSON-LD encodings?
Thank you in advance.
Best regards
Sascha
Re: RDF-related encodings in Titan [message #1824439 is a reply to message #1824397] Wed, 15 April 2020 10:16 Go to previous messageGo to next message
Gábor Szalai is currently offline Gábor SzalaiFriend
Member
The JSON encoder of the TITAN can deal with the special "@..." names of the JSON-LD
Either you can use the generic JSON structure defined in:
https://github.com/eclipse/titan.ProtocolModules.JSON_v07_2006
Or you can specify the exact type definitions and use the "name as " attribute the define the attribute names with @
Example:
"@id" : "http://manu.sporny.org/about#manu"
type set r1 {
charstring id
} with {
variant (id) "name as '@id'"
Result:
id := "http://manu.sporny.org/about#manu"
Re: RDF-related encodings in Titan [message #1824442 is a reply to message #1824439] Wed, 15 April 2020 11:31 Go to previous messageGo to next message
Thanks for your reply, Gábor.
Actually, that's what I tried. For that, I reused the example from here: https://www.eclipse.org/forums/index.php/t/1068704/
Here the excerpt of my custom type:
type set ConnectorSelfDescription {
  charstring connector_type optional,
  ... some more fields ...
 } with {
  variant (connector_type) "name as '@type'"
The result is the following:
index.php/fa/37834/0/
As you can see, the
"@type" : "ids:BaseConnector"
is the first field.
But the result is an error with the following error message:
index.php/fa/37835/0/
Is there anything else I need to consider?
[Updated on: Wed, 15 April 2020 11:33]
Report message to a moderator
Re: RDF-related encodings in Titan [message #1824447 is a reply to message #1824442] Wed, 15 April 2020 12:29 Go to previous messageGo to next message
Elemer Lelik is currently offline Elemer LelikFriend
Hi Sascha,
indeed, the @ character is no accepted in JSON encoding variants; we will look into the possibility to relax this restriction.
As a quick and dirty hack I can propose you the following:
-when encoding, use a token different from @, but easy to detect
- post encoding , replace the token with @
-when receiving the JSON instance, replace @ with token and then decode
(see attached code)
The downside of this-besides being a hack- is that the token will become a restricted expression, i.e. cannot be used in other parts of the JSON; this is of little practical impact, if the token is carefully chosen ("atsupercalifragistic" in my example, to be replaced with "@" back and forth).
For replacement of substrings, functions from TCCConversion_Functions library can be used.
The other option mentioned by Gabor is also valid, I have attached an example as well. JSON will be decoded into a generic TTCN-3 structure that
unfortunately is quite ugly; nonetheless this requires the least initial investment as there is no need of any further TTCN-3 types.
As an example , this JSON-LD
      "@context": {
        "name": "http://xmlns.com/foaf/0.1/name",
        "knows": "http://xmlns.com/foaf/0.1/knows"
      "@id": "http://me.markus-lanthaler.com/",
      "name": "Markus Lanthaler",
      "knows": [
          "name": "Dave Longley"
is decoded as below:
 JSON_object := {
            key := "@context",
            val := {
                JSON_object := {
                        key := "name",
                        val := {
                            JSON_string := "http://xmlns.com/foaf/0.1/name"
                        key := "knows",
                        val := {
                            JSON_string := "http://xmlns.com/foaf/0.1/knows"
            key := "@id",
            val := {
                JSON_string := "http://me.markus-lanthaler.com/"
            key := "name",
            val := {
                JSON_string := "Markus Lanthaler"
            key := "knows",
            val := {
                JSON_array := {
                        JSON_object := {
                                key := "name",
                                val := {
                                    JSON_string := "Dave Longley"
Best regards
Elemer
Re: RDF-related encodings in Titan [message #1824449 is a reply to message #1824442] Wed, 15 April 2020 12:36 Go to previous messageGo to next message
Member
Maybe something is wrong with the type definition. The error message indicates that JSON_PDU doesn't have any field named as "@type"
Is it possible to share the whole type definition and the value to be decoded?
Try to decode the ConnectorSelfDescription directly.
Re: RDF-related encodings in Titan [message #1824451 is a reply to message #1824449] Wed, 15 April 2020 12:53 Go to previous messageGo to next message
Hi Sascha, Gabor ,
please disregard my previous observation about the @ being restricted; it's not , and it should work as Gabor described, see new attachment. Hence no need to rename it.
I agree with Gabor, likely the structure does not tally.
BR
Elemer
Re: RDF-related encodings in Titan [message #1824506 is a reply to message #1824451] Thu, 16 April 2020 14:47 Go to previous message
Hi Elemer, hi Gábor,
thank you for your help. I managed to decode the JSON-LD.
In fact, the issue was a connection between using the variant extension wrongly and a false defined JSON structrure. But thanks to you I knew it should work with JSON-LD messages.
Sascha
Previous Topic:xsd2ttcn on RFC5874
Next Topic:Alternative to GTP_Tunnel_Daemon: osmo-uecups
Current Time: Thu Feb 25 20:05:42 GMT 2021
Powered by FUDForum. Page generated in 0.02290 seconds
