Home » Modeling » TMF (Xtext) » Serialization of unordered, optional attributes(How to force serializer to serialize optional attributes?)
Serialization of unordered, optional attributes [message #1823869] Fri, 03 April 2020 09:43 Go to next message
Stefan Kapferer is currently offline Stefan KapfererFriend
Hi there
I have several rules in my Xtext grammar that use unordered lists of optional attributes like the following:
ContextMap:
  'ContextMap' (name=ID)?
    ('type' ('=')? type=ContextMapType)? &
    ('state' ('=')? state=ContextMapState)? &
    ('yetAnotherAttribute' ('=')? yetAnotherAttribute=JustAnExample)?
In this case the user is able to specify an object 'ContextMap' that has several attributes (type, state, and so on...) that can be declared in any arbitrary order (individual attributes must be optional).
My problem:
If I create/change such an object (EObject) programmatically and serialize it back to the textual representation (DSL), the Xtext serializer always serializes only the first attribute (as declared in the grammar). Even if all attributes have values (not null), only the first attribute makes it to the serialized file. In the example above, only the attribute 'type' is serialized.
How can I force the Xtext serializer to serialize all attributes that are set (not null)?
Thanks for your help!
Re: Serialization of unordered, optional attributes [message #1823870 is a reply to message #1823869] Fri, 03 April 2020 09:47 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
are you sure this is the grammar you use? please make sure you use the correct precedence.
maybe you mean to have
ContextMap:
( ('type' ('=')? type=ContextMapType)? &
('yetAnotherAttribute' ('=')? yetAnotherAttribute=JustAnExample)?)
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: Serialization of unordered, optional attributes [message #1823871 is a reply to message #1823870] Fri, 03 April 2020 09:52 Go to previous messageGo to next message
Yes, sorry, the brackets got lost when I prepared the example for the post.
The actual grammar can also be found here: https://github.com/ContextMapper/context-mapper-dsl/blob/master/org.contextmapper.dsl/src/org/contextmapper/dsl/ContextMappingDSL.xtext
However, the problem remains the same.
Re: Serialization of unordered, optional attributes [message #1823873 is a reply to message #1823871] Fri, 03 April 2020 10:04 Go to previous messageGo to next message
i cannot reproduce this with an hello world grammar.
thus i wonder if there is something in your grammar that causes this.
do you have a reproducing unit test?
Re: Serialization of unordered, optional attributes [message #1824131 is a reply to message #1823873] Wed, 08 April 2020 11:50 Go to previous messageGo to next message
Hmmmm. Indeed, I cannot reproduce it with a hello world grammar as well.
But so far I cannot identity the problem in our grammar/project.
If you could have a quick look if you see something that would be nice. Otherwise I have invest more time to search for the problem.
Project: https://github.com/ContextMapper/context-mapper-dsl
Grammar: https://github.com/ContextMapper/context-mapper-dsl/blob/master/org.contextmapper.dsl/src/org/contextmapper/dsl/ContextMappingDSL.xtext
Re: Serialization of unordered, optional attributes [message #1824136 is a reply to message #1824131] Wed, 08 April 2020 12:36 Go to previous messageGo to next message
the problem is: i dont have time to create a test for your grammar as well
Re: Serialization of unordered, optional attributes [message #1827025 is a reply to message #1824136] Wed, 06 May 2020 08:56 Go to previous message
Thanks for the answers Christian.
I was able to solve my problem in the meantime. The problem was that I always set the attribute values to the first value of the corresponding enum. It looks like as if the first value is interpreted as "default" value and is not serialized.
A short example to illustrate this:
If I have such a rule...:
ContextMap:
... and the values for ContextMapType (just an example) are defined in the following enum:
enum ContextMapType:
  SYSTEM_LANDSCAPE | ORGANIZATIONAL
... then the value is not serialized if I set it to the first value (in this case SYSTEM_LANDSCAPE).
All other values work.
So I was able to solve this for my case by introducing another first value in the enum. Like this:
  UNDEFINED | SYSTEM_LANDSCAPE | ORGANIZATIONAL
Thereby, my values get serialized and UNDEFINED is the only value for which the serializer ignores the attribute.
Previous Topic:Recommended way to use IOutlineTreeProvider.Background
Next Topic:How to call generators in an LSP command
Current Time: Sat Mar 06 02:19:13 GMT 2021
Powered by FUDForum. Page generated in 0.02522 seconds
