Home » Modeling » TMF (Xtext) » Grammar support(Grammar support)
Grammar support [message #1823784] Thu, 02 April 2020 06:03 Go to next message
Virag Purnam is currently offline Virag PurnamFriend
VarDecl:
	{VarDecl} 'int' newVar=NewVar ';'
NewVar:
	{NewVar} ('.' | '.EX')? IDENT
terminal IDENT:
			(('a'..'z'|'A'..'Z'|'_') ('^'|'a'..'z'|'A'..'Z'|'-'|'0'..'9')*)
With the above grammar, I am not able to declare variable.
int .Each;
, This throws error, as it expects 'X' after 'E'.
How to address this issue?
Re: Grammar support [message #1823790 is a reply to message #1823784] Thu, 02 April 2020 07:19 Go to previous messageGo to next message
NewVar:
	{NewVar} ('.' 'EX'?)? IDENT
might fix it with an LL parser such as Xtext, but you'll be in bigger trouble with an LALR parser.
I strongly recommend that you review your grammar since you seem to have something confusing to tools which usually means something confusing to users. The tools provide a really good warning that your grammar is crazy.
What is
int .EXIT;
supposed to be? EX+IT or EXIT?
Ed Willink
Re: Grammar support [message #1823793 is a reply to message #1823790] Thu, 02 April 2020 07:34 Go to previous messageGo to next message
Hi Mr. Ed Willink,
Thanks for the suggestion.
If the variable name starts with '.', then '.EXIT' will be treated as .EX - IT.
Is the grammar change proposed by you will satisfy the mentioned usecase.
Virag
Re: Grammar support [message #1823798 is a reply to message #1823793] Thu, 02 April 2020 08:38 Go to previous messageGo to next message
I think the point is that to "us" it seems like a confusing use case at best. Even if a variable name that happens to start with .EX has some semantic significance, I'd not try to build that significance into the grammar. If you want something in the grammar, better to use "." to mean whatever that is supposed to mean and to use "$' (or some other character not allowed at the start of an IDENT) to mean whatever you're planning to make ".EX" mean. It's just plan weird and confusing what you're trying to do where ".EX" looks just like a variable.
Ed Merks
Re: Grammar support [message #1823815 is a reply to message #1823798] Thu, 02 April 2020 13:53 Go to previous message
I will try if I can simplify the grammar. I will post back here after my experiment.
Thanks.
Previous Topic:Xtext grammar to Java Code Generation
Next Topic:location not found for modeling/tmf/xtext/updates/releases/xpand/
Current Time: Wed Mar 03 06:29:34 GMT 2021
Powered by FUDForum. Page generated in 0.01483 seconds
