Home » Eclipse Projects » Eclipse Titan » IPsec over UDP(How to configure an UDP port to use a fixed src port number )
IPsec over UDP [message #1823688] Tue, 31 March 2020 07:56 Go to next message
Olaf Bergengruen is currently offline Olaf BergengruenFriend
Member
Hi IP experts,
In order that IPsec over UDP works, src and dst port numbers must be fixed, so that the OS can generate the ESP packets for that particular SA (Security Association).
My problem is that when I send UDP packets , e.g. via
 IMS_UDP_Port.send(cs_UDP_IMS(v_SendTo.Buffer,
			       v_Remote.IpAddr.V4.Addr,
			       v_Remote.Port));
then my OS selects random src port numbers, which results in no valid IPsec SA.
My question: How can I configure via the TTCN UDP ASPs my underlying socket so that the OS sets a fixed src port numbe.
Thanks for any hint,
Olaf
Re: IPsec over UDP [message #1823689 is a reply to message #1823688] Tue, 31 March 2020 08:24 Go to previous messageGo to next message
Gábor Szalai is currently offline Gábor SzalaiFriend
Member
First open an UDP socket with the ASP_UDP_open message
wait for the ASP_UDP_open_result, which returns the id of the opened socket.
Finally use the ASP_UDP_message to send the message.
Gábor
Re: IPsec over UDP [message #1823700 is a reply to message #1823689] Tue, 31 March 2020 10:44 Go to previous messageGo to next message
Member
Thanks Gábor,
I read from your comment, that what I want, i.e. to have a fixed src port can be done with the existing ASPs, I don't need to manipulate the PCO cc implementation. Is this right?.
Basically that's what I am doing, so I will code a simple example and check exactly the parameters and whether I leave out optional parameters and ids when using the ASPs.
Olaf
Re: IPsec over UDP [message #1823702 is a reply to message #1823700] Tue, 31 March 2020 10:59 Go to previous messageGo to next message
Elemer Lelik is currently offline Elemer LelikFriend
Hi Olaf,
that's right, you can request a specific local port (src) in ASP_UDP_open:
type record ASP_UDP_open{
	  AddressType       remote_addr optional,
	  PortType          remote_port optional,
	  AddressType       local_addr optional,
	  PortType          local_port optional
Of course, local_port should be given the value of the desired src port.
This will be acknowledged with ASP_UDP_open_result:
  type record ASP_UDP_open_result{
	  AddressType       local_addr,
	  PortType          local_port,
	  integer           id
BR
Elemer
Re: IPsec over UDP [message #1823705 is a reply to message #1823702] Tue, 31 March 2020 12:38 Go to previous messageGo to next message
Member
Wow, Gabor and Elemer: It works as you said! Now the UDP packets have the right src port.
The point was that I need to store the port or socket Id when opening the socket, and use it in the ASP when sending the UDP payload.
Thanks!! (I looked ours on the IPsec configuration)
Olaf
Re: IPsec over UDP [message #1824422 is a reply to message #1823705] Wed, 15 April 2020 07:05 Go to previous messageGo to next message
Member
Hi all,
may be one of you have an idea how can I solve my next problem.
In case I have several pairs of ports which shall be connected over IPsec, I don't know how to set the IPsec configuration, such that the OS selects the right spi when I, the Tester, sends an UDP packet over a particular port.
In detail:
   IUT                             Tester
   Port-x   <--------------------> Port-1
                     <-- spi-1 --
   Port-y   <--------------------> Port-2
                     <-- spi-2 --
   Port-z   <--------------------> Port-3
                     <-- spi-3 --
The configuration in the Tester (only the configuration in direction Tester --> IUT):
 f_IPsec_SADB_add (Tester_IPaddr, IUT_IPaddr, esp, spi_1,...);
 f_IPsec_SADB_add (Tester_IPaddr, IUT_IPaddr, esp, spi_2,...);
 f_IPsec_SADB_add (Tester_IPaddr, IUT_IPaddr, esp, spi_3,...);
 f_IPsec_SPDB_add (Tester_IPaddr, -, port_1, IUT_IPaddr, -, -, udpProto, outDir, ...);
 f_IPsec_SPDB_add (Tester_IPaddr, -, port_2, IUT_IPaddr, -, -, udpProto, outDir, ...);
 f_IPsec_SPDB_add (Tester_IPaddr, -, port_3, IUT_IPaddr, -, -, udpProto, outDir, ...);
But how can the OS know, when sending via Port_1.sendto, that it shall use spi-1?
I would appreciate any hint on this issue,
Olaf
Re: IPsec over UDP [message #1824534 is a reply to message #1824422] Fri, 17 April 2020 05:57 Go to previous messageGo to next message
Hi Olaf,
f_IPsec_SPDB_add and f_IPsec_SADB_add are only wrappers to the corresponding Linux kernel functions, so
details about IPSec can be obtained from Linux kernel implementation and configuration descriptions.
For outbound packets:
IPSec founds the first match (based on srcAddress,srcPort,dstAddress,dstPort) in the
Security Policy Database (SPD)
If the policy requires protection, IPSec maps the packet to the right Security Association (SA) in the
Security Association Database (SAD)
If no SA exists, IPSec invokes the IKE service to create an SA pair
If SA exists, the packet is encrypted/authenticated
(see figure below)
index.php/fa/37851/0/
For incoming IPSec packets, IPSec looks up the inbound SA in the SAD based on SPI (Security Parameter Index)
(this is exchanged between sender and receiver during the initial negotiation and it is contained in the IPSec packet )
IPSec then processes (decrypts/authenticates) the packet based on SA
For incoming non-IPSec packets, IPSec finds the first matching policy in SPD and verifies that the action
is BYPASS; if not , the packet is dropped.
(see figure below)
index.php/fa/37852/0/
So how does this look in practice?
For outgoing packets, SPD is built with f_IPsec_SPDB_add (see TCCIPsec_Functions.ttcn)
external function f_IPsec_SPDB_add (
    in charstring               srcAddress,
    in integer                  srcPrefixLen := c_TCCIPsec_prefixAll,
    in integer                  srcPort := c_TCCIPsec_anyPort,
    in charstring               dstAddress,
    in integer                  dstPrefixLen := c_TCCIPsec_prefixAll,
    in integer                  dstPort := c_TCCIPsec_anyPort,
    in TCCIPsec_TranspProto     transpProto := anyTranspProto,
    in TCCIPsec_PolicyDirection dir,
    in TCCIPsec_PolicyRule      rule
  ) return TCCIPsec_Result;
where(see TCCIPsec_Definitions.ttcn)
type union TCCIPsec_PolicyRule {
    TCCIPsec_DiscardRule          discard,  //DISCARD
    TCCIPsec_NoneRule             noneRule, //BYPASS
    TCCIPsec_RuleList             ipSec             //PROTECT
  type record of TCCIPsec_Rule TCCIPsec_RuleList;
   type record TCCIPsec_Rule {
    TCCIPsec_Protocol             protocol, //ah, esp
    TCCIPsec_Mode                 mode,  //transport or tunnel
    TCCIPsec_RuleLevel            level
  type union TCCIPsec_RuleLevel {
    TCCIPsec_DefaultLevel         defaultLevel,
    TCCIPsec_UseLevel             use,
    TCCIPsec_RequireLevel         require,
    TCCIPsec_UniqueLevel          unique
  type record TCCIPsec_DefaultLevel {};
  type record TCCIPsec_UseLevel {};
  type record TCCIPsec_RequireLevel {};
  type record TCCIPsec_UniqueLevel {
    integer id
  //An SA is linked to an SP when the SA has a policyId extension with the
  //value of the SP's id.
According to
http://manpages.ubuntu.com/manpages/bionic/man3/ipsec_set_policy.3.html
about IPSec rule level
"level must be set to one of the following: default, use, require, or
unique
default means that the kernel should consult the system default policy defined by sysctl(8), such as net.inet.ipsec.esp_trans_deflev. See ipsec(4) regarding the system default.
use means that a relevant SA can be used when available, since the kernel may perform IPsec operation against packets when possible. In this case, packets can be transmitted in clear (when SA is not available), or encrypted (when SA is available).
require means that a relevant SA is required, since the kernel must
perform IPsec operation against packets.
unique is the same as require, but adds the restriction that the SA for outbound traffic is used only for this policy. You may need the identifier in order to relate the policy and the SA when you define the SA by manual keying. You can put the decimal number as the identifier after unique like unique: number. number must be between 1 and 32767 .
If the request string is kept unambiguous, level and slash prior to level can be omitted. However, it is encouraged to specify them explicitly to avoid unintended behavior. If level is omitted, it will be interpreted as default."
Example:
     res := f_IPsec_SPDB_add ( "192.168.1.1", -, 2001, "192.168.1.2", -, 3001,
    udpProto, outDir,
    { ipSec := { { protocol := esp, mode := { transport := {} }, level := { unique := { id := 101 } } } } } ); //pointer to SA
  res := f_IPsec_SADB_add ( "192.168.1.1",  "192.168.1.2", esp,
        11001,  //this is SPI
    { { policyId := 101 }, { hardLifetime := 180 }, { softLifetime := 60 } }, //policyId links SA to SP
    { encrAndAuth := {
        ealgo := EALG_3DESCBC, ekey := { text := "123456789012345678901234" },
        aalgo := AALG_MD5HMAC, akey := { text := "1234567890123456" } } } );
where f_IPsec_SADB_add builds the SAD:
      external function f_IPsec_SADB_add (
    in TCCIPsec_Protocol        protocol,  //ah or esp
    in integer                  spi,
    in TCCIPsec_ExtensionList   extensionList := {}, //this contains policyId
    in TCCIPsec_Algorithm       alg,
    in boolean                  setparitybit := false,
    in boolean                  useNatt := false,
    in TCCIPsec_IPsecMode       ipSecMode := anyMode   //transport or tunnel
  type union TCCIPsec_Extension {
    integer                       policyId,  //Identifier to link a Security Association (SA) to Security Policy (SP)
    integer                       hardLifetime,
    integer                       softLifetime
so for outgoing packets, SPD is looked up (based on src and dst addresses/ports) , and the pointer to SA ( level := { unique := { id := 101 } } ) is found; so the appropriate SA is used to encrypt/authenticate .
On the SA side, policyId ( { policyId := 101 }, )links SA to a Security Policy.
SPI is only used in incoming direction; during initial negotiation, the sender will send information about SA/SPI to the receiver, which will build it's own SAD.
I hope this answers your question.
Best regards
Elemer
  • Attachment: IPSecOG.png
    (Size: 32.53KB, Downloaded 84 times)
  • Attachment: IPSecIC.png
    (Size: 38.07KB, Downloaded 87 times)
Re: IPsec over UDP [message #1826064 is a reply to message #1824534] Sat, 18 April 2020 04:43 Go to previous message
Member
Wow, Elemer, you are always saving me from catastrophe and nervous collapse :-)
It works!
The secret was to use the policy Id mapping SAs and SPs!
Now I can very cleanly implement the SPI mapping for an MCPTT or IMS Tester as required in TS 36.523-3 Figure 4.2.5.2.3.1-2, which is nightmare for programmers in the Tester, and in the Clients and Servers :-)
Thanks again,
Olaf
Previous Topic:Alternative to GTP_Tunnel_Daemon: osmo-uecups
Next Topic:more strict 'ifpresent' handling in titan 6.6.x compared to previous versions
Current Time: Sun Jan 17 10:57:33 GMT 2021
Powered by FUDForum. Page generated in 0.02535 seconds
