Home » Eclipse Projects » Sirius » External Java Action Create Viewpoint Project(External Java Action Create Viewpoint Project)
External Java Action Create Viewpoint Project [message #1823316] Tue, 24 March 2020 15:33 Go to next message
In my odesign I define a Popup Menu and within it an External Java Action. This action only creates a Viewpoint Specification Project programmatically using ViewpointSpecificationProject.createNewViewpointSpecificationProject. In the current diagram, I currently show one element and this element disappears, when the user clicks the action that calls this external java action. So, after this action finish, I get an empty diagram.
I really don't understand this behaviour. I have tried to debut but nothing. Any hints?
I am using Eclipse Photon (4.8) and Sirius (6.0.2)
Thanks in advance.
Anthony
Re: External Java Action Create Viewpoint Project [message #1823346 is a reply to message #1823316] Wed, 25 March 2020 06:36 Go to previous messageGo to next message
It's difficult to be sure, but one possible explanation would be that the new Viewpoint Specification Project your created defines a Viewpoint and Diagram with the same name as the one you are currently using. In that case Sirius would automatically detect the new viewpoint, and depending on you exact setup use the newly created one to try to refresh the existing diagram, which can only result in a mess.
Pierre-Charles
Re: External Java Action Create Viewpoint Project [message #1823381 is a reply to message #1823346] Wed, 25 March 2020 16:10 Go to previous messageGo to next message
Hello Pierre-Charles,
Thanks for your answer.
Probably that is the problem. The thing is that the created odesign has a different name.
I attached a code sample, Would please take a look at the code?
src-> source plugins
Viewpoint Specification Project = sample.project.design
sample.project.design.action.ExternalJavaAction1 -> Implementation of the external Java Action
runtime -> runtime environment
/runtime/sample.mm when you open the diagram right Menu Sample -> Sample (These steps are to execute the external java action)
Thanks in advance.
Kind regards,
Anthony
Re: External Java Action Create Viewpoint Project [message #1823491 is a reply to message #1823381] Fri, 27 March 2020 06:37 Go to previous message
I would really appreciate an answer on this topic. Could any of you debug the code? Let me know if I have to do anything else.
Thanks in advance.
Kind regards,
Anthony
Previous Topic:Changing a diagram element's color without changing its model
Next Topic:Graphical elements extension to Sirius?
Current Time: Thu Jul 10 00:49:57 EDT 2025
Powered by FUDForum. Page generated in 0.06432 seconds
