Home » Eclipse Projects » Jubula » Can extracted tests from lean FT and UFT be exported to Jubula?(Can extracted tests from lean FT and UFT be exported to Jubula?)
Can extracted tests from lean FT and UFT be exported to Jubula? [message #1823163] Fri, 20 March 2020 15:21 Go to next message
Kostiantyn Kuzmenko is currently offline Kostiantyn KuzmenkoFriend
Can extracted tests from lean FT and UFT ( VB script and Java ) be exported to Jubula?
Re: Can extracted tests from lean FT and UFT be exported to Jubula? [message #1823607 is a reply to message #1823163] Mon, 30 March 2020 08:12 Go to previous message
Marvin Mueller is currently offline Marvin MuellerFriend
not really Jubula does not have any converter or similar to convert from one test to another. Also it may also make no sense since the approach may differ and the conversion should be done by someone who nows the current test struckture.
best regards
Marvin Mueller
Previous Topic:Jubula test in Exclipse
Next Topic:Problem with testing various components
Current Time: Sun Jul 25 09:40:07 GMT 2021
Powered by FUDForum. Page generated in 0.01900 seconds
