Re: Unable to run Java project [message #1822610 is a reply to message #1822609] |
Tue, 10 March 2020 13:27 |
Evgeny Erenburg Messages: 10 Registered: February 2020 |
Stephan Herrmann wrote on Tue, 10 March 2020 13:17Quote:But it has no Java IDE. Only C/C++ Project environment.
Then you probably didn't install the package you want. Did you see that there is a package called "Eclipse IDE for Java Developers"?
Yes but it goes as a stand alone packet - eclipse-java-kepler-SR1-win32-x86_64.zip.
Should I port it in IDE somehow?
[Updated on: Tue, 10 March 2020 13:28] Report message to a moderator
Re: Unable to run Java project [message #1822673 is a reply to message #1822670] |
Wed, 11 March 2020 09:22 |
Emmanuel Chebbi wrote on Wed, 11 March 2020 08:57Evgeny Erenburg wrote on Wed, 11 March 2020 08:55Thank you. Now I can open an existing project but when I try to build I get this error -
The project cannot be built until build path errors are resolved. Do I need to configure something?
You are likely missing a dependency, the solution depends on what is missing exactly. Could you:
- Check the error displayed in the Problems view to have more details about what is missing,
- Tell us what kind of project it is (Maven, plain Java, etc.),
- Open the project's build path (right-click on the project > Properties > Java Build Path > Order and Export) and check if a resource is marked as missing (with a little red cross)
I don't know how to find the project's kind. But I found this is missing -
Unbound classpath container: 'JRE System Library [jre1.8.0_25]'
Can I download and install the library?
I see. Thank you. It's an old library. I choose the new one jre1.8.0_241 and it works.
[Updated on: Wed, 11 March 2020 09:41] Report message to a moderator
FUDForum. Page generated in 0.03902 seconds
