Home » Modeling » EMF » Generation of ID's (How to generate ID's of classes automatically? )
Generation of ID's [message #1822573] Tue, 10 March 2020 08:31 Go to next message
Adil Bhatti is currently offline Adil BhattiFriend
Good day..!!
I have used XML language in generator to create an application. Inside application i want to generate GUID and link it with other classes as references. How can i do it in generator? Is it possible to make some changes in meta-model so that it creates ID automatically?
Will be looking forward for a response.
Adil
Re: Generation of ID's [message #1822618 is a reply to message #1822573] Tue, 10 March 2020 14:29 Go to previous messageGo to next message
The xmi:id is nothing to do with your model; it is an artifact of its serialization in XML. Consequently no tools provide first class support for xmi:id although some provide a backdoor helper.
In EMF, the serialization is controlled by your XXXResourceImpl, provided you enabled resource generation in your genmodel. You can override useIds or useUUIDs in your XXXResourceImpl or even implement getId/setID to do something really specialized.
Be very careful about very strong xmi:ids. You can very easily discover that they can be a major PITA, since nothing can ever evolve ever again unless you have some tedious reconciliation wrt previous xmi:ids. I recommend that you do nothing to 'improve' your xmi:ids until you have used the defaults for at least 3 months and think very hard about what you are actually trying to achieve before doing something different.
Ed Willink
Re: Generation of ID's [message #1822631 is a reply to message #1822618] Tue, 10 March 2020 15:19 Go to previous messageGo to next message
Thanks for your reply. Purpose is to automatically generate ID's on run-time using GUID. Please see attached screenshot. This application was generated using XML code in Acceleo. Next thing what i am looking to
implement is GUID. From the image. Water level under American coffee is referring to water level under instance list. In order to do implementation, i need to write java code which implements GUID. Is it possible to
use header files of Java and write Java code for GUID and connect somehow with XML to achieve the purpose?
If yes, then kindly let me know, i am stuck here since many days now.
Looking forward
Adil
[Updated on: Tue, 10 March 2020 15:20]
Report message to a moderator
Re: Generation of ID's [message #1822676 is a reply to message #1822631] Wed, 11 March 2020 09:37 Go to previous message
OK. It seems like your use of XML and ID in the same paragraph confused me. You are not interested in xmi:id at all, but an ordinary model attribute that has a GUID value.
It is fairly easy to specify a custom EDataType that auto-allocates unique values using the EcoreUtil.generateUUID().
Once you have implemented it, you can then start to tackle the following bugs that are probably due to a lack of consideration of what you actually want to achieve.
- when you reload the model different UUIDs are allocated
- when you cut and paste in the editor, duplicate UUIDs appear
- when you change an ancestor, the UUID is not changed
- when you change an ancestor and then change it back again the UUID remains changed
I think I might be inclined to maintain a load-time GUID-to-EObject map, a think-of-a-new-GUID cell editor action, and a validation that each actual GUID is consistent with load-time and subsequently created elements.
Ed Willink
Previous Topic:How to add a attribute or property to a EAttribute type?
Next Topic:Ecore data types for array, vector and list
Current Time: Mon May 10 02:58:43 GMT 2021
Powered by FUDForum. Page generated in 0.01708 seconds
