Eclipse wouldn't start [message #1822565] |
Tue, 10 March 2020 05:13 |
Adam Huang Messages: 2 Registered: March 2020 |
Hi everyone,
My Eclipse used to run just fine, but after two months of holiday, it just wouldn't start. This is my .log, any advice is appreciated, thank you very much.
!SESSION 2020-03-10 18:06:54.531 -----------------------------------------------
eclipse.buildId=4.10.0.I20181206-0815
java.version=1.8.0_241
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_NZ
Framework arguments: -product org.eclipse.epp.package.java.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.java.product
!ENTRY org.eclipse.egit.core 1 0 2020-03-10 18:07:01.712
!MESSAGE Using Apache MINA sshd as ssh client.
!ENTRY org.eclipse.jface 2 0 2020-03-10 18:07:02.807
!MESSAGE Keybinding conflicts occurred. They may interfere with normal accelerator operation.
!SUBENTRY 1 org.eclipse.jface 2 0 2020-03-10 18:07:02.807
!MESSAGE A conflict occurred for CTRL+F4:
Binding(CTRL+F4,
ParameterizedCommand(Command(org.eclipse.ui.file.close,Close,
Close the active editor,
Category(org.eclipse.ui.category.file,File,null,true),
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@5e584389,
,,true),null),
org.eclipse.ui.defaultAcceleratorConfiguration,
org.eclipse.ui.contexts.window,,,system)
Binding(CTRL+F4,
ParameterizedCommand(Command(org.scala.tools.eclipse.search.commands.OpenTypeHierarchy,Open Type Hierarchy,
Category(org.scala.tools.eclipse.search.commands,Search - Scala,Search - Scala,true),
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@42491839,
,,true),null),
!ENTRY org.eclipse.osgi 4 0 2020-03-10 18:07:38.550
!MESSAGE Application error
!STACK 1
java.lang.OutOfMemoryError: Java heap space
at java.util.Arrays.copyOf(Unknown Source)
at java.util.ArrayList.grow(Unknown Source)
at java.util.ArrayList.ensureExplicitCapacity(Unknown Source)
at java.util.ArrayList.ensureCapacityInternal(Unknown Source)
at java.util.ArrayList.add(Unknown Source)
at org.eclipse.jface.text.TextPresentation.addStyleRange(TextPresentation.java:230)
at org.eclipse.wst.sse.ui.internal.rules.PresentationCollector.add(PresentationCollector.java:65)
at org.eclipse.wst.sse.ui.internal.provisional.style.AbstractLineStyleProvider.prepareTextRegions(AbstractLineStyleProvider.java:352)
at org.eclipse.wst.sse.ui.internal.provisional.style.AbstractLineStyleProvider.prepareRegions(AbstractLineStyleProvider.java:249)
at org.eclipse.wst.sse.ui.internal.rules.StructuredDocumentDamagerRepairer.createPresentation(StructuredDocumentDamagerRepairer.java:43)
at org.eclipse.wst.sse.ui.internal.provisional.style.StructuredPresentationReconciler.createPresentation(StructuredPresentationReconciler.java:724)
at org.eclipse.wst.sse.ui.internal.provisional.style.StructuredPresentationReconciler.processDamage(StructuredPresentationReconciler.java:870)
at org.eclipse.wst.sse.ui.internal.provisional.style.StructuredPresentationReconciler$InternalListener.inputDocumentChanged(StructuredPresentationReconciler.java:271)
at org.eclipse.wst.sse.ui.internal.provisional.style.StructuredPresentationReconciler.install(StructuredPresentationReconciler.java:600)
at org.eclipse.wst.sse.ui.internal.StructuredTextViewer.updateHighlighter(StructuredTextViewer.java:987)
at org.eclipse.wst.sse.ui.internal.StructuredTextViewer.setDocument(StructuredTextViewer.java:865)
at org.eclipse.jface.text.source.SourceViewer.setDocument(SourceViewer.java:613)
at org.eclipse.ui.texteditor.AbstractTextEditor.initializeSourceViewer(AbstractTextEditor.java:3970)
at org.eclipse.ui.texteditor.AbstractTextEditor.createPartControl(AbstractTextEditor.java:3440)
at org.eclipse.ui.texteditor.StatusTextEditor.createPartControl(StatusTextEditor.java:64)
at org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.createPartControl(AbstractDecoratedTextEditor.java:451)
at org.eclipse.wst.sse.ui.StructuredTextEditor.createPartControl(StructuredTextEditor.java:1566)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPartControl(CompatibilityPart.java:156)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityEditor.createPartControl(CompatibilityEditor.java:102)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:367)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:58)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:1001)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:966)
!ENTRY org.eclipse.e4.ui.workbench 4 0 2020-03-10 18:07:40.304
!MESSAGE
!STACK 0
at org.eclipse.jface.resource.JFaceResources.getResources(JFaceResources.java:212)
at org.eclipse.jface.resource.JFaceResources.getResources(JFaceResources.java:230)
at org.eclipse.ui.part.WorkbenchPart.dispose(WorkbenchPart.java:103)
at org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart.dispose(PackageExplorerPart.java:481)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.invalidate(CompatibilityPart.java:264)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.destroy(CompatibilityPart.java:424)
at org.eclipse.e4.core.internal.di.InjectorImpl.disposed(InjectorImpl.java:462)
at org.eclipse.e4.core.internal.di.Requestor.disposed(Requestor.java:159)
at org.eclipse.e4.core.internal.contexts.ContextObjectSupplier$ContextInjectionListener.update(ContextObjectSupplier.java:81)
at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(TrackableComputationExt.java:114)
at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.handleInvalid(TrackableComputationExt.java:77)
at org.eclipse.e4.core.internal.contexts.EclipseContext.dispose(EclipseContext.java:187)
at org.eclipse.e4.core.internal.contexts.EclipseContext.dispose(EclipseContext.java:172)
at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.dispose(EclipseContextOSGi.java:102)
at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.bundleChanged(EclipseContextOSGi.java:144)
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:911)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:233)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:151)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:233)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:140)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:132)
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:194)
at org.eclipse.osgi.container.Module.publishEvent(Module.java:483)
at org.eclipse.osgi.container.Module.doStop(Module.java:641)
at org.eclipse.osgi.container.Module.stop(Module.java:505)
at org.eclipse.osgi.container.SystemModule.stop(SystemModule.java:207)
at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$EquinoxSystemModule$1.run(EquinoxBundle.java:213)
Re: Eclipse wouldn't start [message #1822616 is a reply to message #1822565] |
Tue, 10 March 2020 14:00 |
You seem to have left open an editor and running out of memory on startup. How much physical memory is there on the system, and what's the maximum set for Eclipse to use when you start it?
_
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: Eclipse wouldn't start [message #1822644 is a reply to message #1822642] |
Tue, 10 March 2020 17:07 |
Nitin Dahyabhai wrote on Tue, 10 March 2020 14:00You seem to have left open an editor and running out of memory on startup. How much physical memory is there on the system, and what's the maximum set for Eclipse to use when you start it?
Hi, Nitin
Thanks for the reply, problem is solved after setting the memory to 2048mb
Ed Merks wrote on Tue, 10 March 2020 16:59If there isn't already a line like -Xmx2048 in the eclipse.ini add one or make the value bigger on the line that's there.
Thank you Ed, your method works, now I can start Eclipse again :D
[Updated on: Tue, 10 March 2020 17:12] Report message to a moderator
FUDForum. Page generated in 0.03149 seconds
