Home » Newcomers » Newcomers » Eclipse Installer Error(Eclipse just won't download, help?)
Eclipse Installer Error [message #1822417] Thu, 05 March 2020 14:43 Go to next message
Hello, I was trying to download Eclipse and then it gave me an error. I tried countless methods, none of them worked. Does anyone have any advice?
This is the error I encountered:
ERROR: org.eclipse.equinox.p2.engine code=4 An error occurred during the org.eclipse.equinox.internal.p2.engine.phases.CheckTrust phase.
at org.eclipse.oomph.util.OomphPlugin.coreException(OomphPlugin.java:280)
at org.eclipse.oomph.p2.internal.core.ProfileTransactionImpl$3.commit(ProfileTransactionImpl.java:549)
at org.eclipse.oomph.p2.internal.core.ProfileTransactionImpl.commit(ProfileTransactionImpl.java:341)
at org.eclipse.oomph.setup.p2.impl.P2TaskImpl.perform(P2TaskImpl.java:815)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.doPerformNeededSetupTasks(SetupTaskPerformer.java:3827)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.performNeededSetupTasks(SetupTaskPerformer.java:3755)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.performTriggeredSetupTasks(SetupTaskPerformer.java:3736)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.perform(SetupTaskPerformer.java:3629)
at org.eclipse.oomph.setup.internal.installer.SimpleVariablePage.installPerform(SimpleVariablePage.java:1325)
at org.eclipse.oomph.setup.internal.installer.SimpleVariablePage.access$32(SimpleVariablePage.java:1187)
at org.eclipse.oomph.setup.internal.installer.SimpleVariablePage$20.run(SimpleVariablePage.java:1132)
Re: Eclipse Installer Error [message #1822434 is a reply to message #1822417] Fri, 06 March 2020 00:15 Go to previous message
Probably the full information included the name of the file that it's checking. Perhaps a corrupt file was downloaded and is now in the bundle pool. This page has some details for trying to repair the pool:
https://www.eclipse.org/setups/installer/question/
Specifically these details:
Use the eclipse installer's Bundle Pools... menu item to manage where this pool is physically located on disk; this location can become large. The Bundle Pool Management dialog supports garbage collecting of unused artifacts, i.e., if you delete an installation, the artifacts it uses can potentially be removed from disk. In addition, if some artifact becomes corrupted, or if a corrupted artifact is downloaded from some mirror site, this dialog can be used to detect the damage and to repair it.
Previous Topic:Eclipse Information center as a Web Archive
Next Topic:I have a Color issue
Current Time: Fri May 16 12:14:09 EDT 2025
Powered by FUDForum. Page generated in 0.07828 seconds
