Home » Eclipse Projects » GEF » Is GEF 5.1.0 compatible with efxclipse 3.5.0(Is GEF 5.1.0 compatible with efxclipse 3.5.0)
Is GEF 5.1.0 compatible with efxclipse 3.5.0 [message #1822373] Thu, 05 March 2020 02:54 Go to next message
Hi All,
Is GEF 5.1.0 compatible with efxclipse 3.5.0 ?
Re: Is GEF 5.1.0 compatible with efxclipse 3.5.0 [message #1822384 is a reply to message #1822373] Thu, 05 March 2020 07:22 Go to previous message
Hi Girijanandan,
yes, it should work fine.
GEF depends on JavaFX, which can be provided in an OSGi context by e(fx)clipse.
Where to find JavaFX depends on your Java version. More recent versions of e(fx)clipse are compatible with more recent versions of Java.
When using Java 7 or 8, e(fx)clipse will find the necessary jars in your Java installation.
When using Java 11, you need to set a javafx SDK directory, so that e(fx)clipse can find JavaFX.
Matthias
Previous Topic:Where to get I18N Bundle for GEF 3.11
Next Topic:Selecting a node after creation
Current Time: Tue May 13 13:43:27 EDT 2025
Powered by FUDForum. Page generated in 0.05441 seconds
