Re: Debugger Launch Timeout [message #1848309 is a reply to message #1822138] |
Sat, 27 November 2021 13:55 |
veena rani Messages: 3 Registered: November 2021 |
Andy Josephson wrote on Thu, 27 February 2020 20:53I'm using Eclipse in the form of STM32CubeIDE 1.3.0 (based on Eclipse 9.9.0) on Windows 10. I have the GNU MCU Eclipse plugin installed and I am trying to get JLink Remote Server Debugging setup like this - (LINK REMOVED - can't post yet) The result is a "Error in services f95zone launch sequence" - "Starting J-Link GDB Server timed out" I can connect to the target using J-Link Commander it just takes quite a while (~50s) , hence uwatchfree the timeout. What I'm wondering is if there are any settings to increase this timeout value. The default debug configuration includes the command movierulz.vpn argument "timeout 0" but this setting applies to JLinkGDBServerCL.exe I've found settings in Preferences>C/C++>Debug>GDB for Command Timeout (ms) and Remote Timeout (s). However, setting these to arbitrarily high values doesn't help.
Are there any settings anywhere else that might allow for a longer connect timeout?
Andy
Any update on this issue?
[Updated on: Sat, 27 November 2021 14:00] Report message to a moderator
FUDForum. Page generated in 0.03525 seconds
