Home » Modeling » Papyrus » "Values" compartment for blocks(Does Papyrus provide a "values" compartment for value properties in blocks)
"Values" compartment for blocks [message #1821908] Sat, 22 February 2020 16:20 Go to next message
Ben Benford is currently offline Ben BenfordFriend
I do not see a values compartment option for blocks when value properties are defined. Is there an option to display the values compartment or do i just need to type an attribute with a valueType and display it in the "attributes" compartment?
[Updated on: Sat, 22 February 2020 17:46]
Report message to a moderator
Re: "Values" compartment for blocks [message #1821939 is a reply to message #1821908] Mon, 24 February 2020 07:01 Go to previous messageGo to next message
jb tw is currently offline jb twFriend
Member
See in the figure or press "ctrl + F5"
index.php/fa/37443/0/
Re: "Values" compartment for blocks [message #1821962 is a reply to message #1821939] Mon, 24 February 2020 15:40 Go to previous message
I understand how to show the compartments. The issue is that there is no option to display a "values" compartment in a block and I believe there should be according to SysML specs. I am using SysML 1.4 in Papyrus.
Previous Topic:Generate code from imported profile.
Next Topic:Diagram export font different from what's on the screen
Current Time: Wed Mar 03 22:18:39 GMT 2021
Powered by FUDForum. Page generated in 0.01898 seconds
