Home » Eclipse Projects » Eclipse Platform » Views disappear after installing Galileo
Views disappear after installing Galileo [message #336818] Sun, 05 July 2009 15:52 Go to next message
Mark Mising name is currently offline Mark Mising nameFriend
Member
After upgrade to Galileo, the list of views from
Window->Show_View->Other... is about 1/3 the size it was before, I some of
these view that are no longer listed have also disappeared from my
Perspective layout. How do I get them back? The *.jar files for these
"missing" plugins still exist in the /usr/local/eclipse/plugins directory.
Re: Views disappear after installing Galileo [message #336819 is a reply to message #336818] Sun, 05 July 2009 16:06 Go to previous messageGo to next message
Chris Aniszczyk is currently offline Chris AniszczykFriend
> of these view that are no longer listed have also disappeared from my
It could be that capabilities aren't enabled that you want.
Go to preferences, General->Capabilities
I'd enable the things interested to you.
I recommend NOT ENABLING the 'Classic Update' capability.
Let me know if that works!
Chris Aniszczyk | EclipseSource Austin | +1 860 839 2465
http://twitter.com/eclipsesource | http://twitter.com/caniszczyk
Re: Views disappear after installing Galileo [message #336821 is a reply to message #336819] Sun, 05 July 2009 18:12 Go to previous messageGo to next message
Member
Thanks, for responding, but... Hmmmmm! I don't have a
General->Capabilities. I am not using the EE version... just the "Eclipse
for Java Developers". Would that make a difference? I'm running on RH
Linux EL4...
Mark
Re: Views disappear after installing Galileo [message #336822 is a reply to message #336821] Sun, 05 July 2009 22:14 Go to previous messageGo to next message
Yves Schumann is currently offline Yves SchumannFriend
Member
Hi Mark
> "Eclipse for Java Developers". Would that make a difference? I'm
> running on RH Linux EL4...
I don't know if there is a difference on this between the Eclipse
version but you need the Capabilities-Feature installed!
MfG
Yves
Ballistische Experimente mit kristallinem H2O unterliegen auf dem
Gelände der pädagogischen Institution striktester Prohibition.
Re: Views disappear after installing Galileo [message #336829 is a reply to message #336822] Mon, 06 July 2009 11:09 Go to previous messageGo to next message
Member
OK, but how do I get it installed? I downloaded JavaEE with Birt version
of Eclipse and it *still* does not have this "capabilities" feature in the
Preferences. Is that a plug-in itself that I need to get? But from
where? How is it that some versions of Galileo have the "capabilities"
feature when others don't?
Mark
Re: Views disappear after installing Galileo [message #336837 is a reply to message #336818] Mon, 06 July 2009 16:12 Go to previous messageGo to next message
What views are you missing?
Note that if you were using the JEE package before and the Java
Developer package now, you should expect that some features will be
absent, since the JEE package contains a lot of things that the Java Dev
package does not.
Hope this helps,
Eric
Re: Views disappear after installing Galileo [message #336838 is a reply to message #336837] Mon, 06 July 2009 17:28 Go to previous messageGo to next message
Member
The views I am missing are the add-ons, not the baseline plug-ins. For
example, cz.mz.milan1.colors_0.0.2.jar and
zigen.plugin.db_1.0.9.v20080914.jar still exist in the eclipse/plugins
directory, but I can no longer choose these view from the list as before.
Both are quite useful and I miss not having them. I don't see any
complaints about these in the Eclipse log.
BTW, I downloaded/installed the JavaEE w/ Birt, but yet my results are the
same. I should also note that I work on a box that is locked behind a
firewall, and so without Internet access on the development computer, I
have to download tarballs any time I want to upgrade instead of using
Eclipse's "Software Update" feature.
Mark
Re: Views disappear after installing Galileo [message #336840 is a reply to message #336829] Tue, 07 July 2009 07:05 Go to previous messageGo to next message
Member
Hi Mark
> version of Eclipse and it *still* does not have this "capabilities"
> feature in the Preferences. Is that a plug-in itself that I need to
> get? But from where? How is it that some versions of Galileo have the
> "capabilities" feature when others don't?
On the install dialog take a look on the section "General Purpose
Tools", there you can find "Galileo Capability Definitions". Is that
installed on your Eclipse?
MfG
Yves
"Wenn du kritisiert wirst, dann musst du irgend etwas richtig machen.
Denn man greift nur denjenigen an, der den Ball hat." -- Bruce Lee
Re: Views disappear after installing Galileo [message #336844 is a reply to message #336838] Tue, 07 July 2009 13:25 Go to previous message
Originally posted by: wegener.cboenospam.com
"Mark " <Mark.Fenbers@noaa.gov> wrote in message
news:731ca85b05d2fb961b9fbfeb0e750df8$1@www.eclipse.org...
> Mark
Have you verified with the plugin providers that their plugins are
compatible with Eclipse 3.5?
Previous Topic:distributing non java executables along with a plugin
Next Topic:ComboBoxViewerCellEditor problem
Current Time: Tue Apr 16 04:51:56 GMT 2024
Powered by FUDForum. Page generated in 0.46775 seconds
