Re: Installing one plugin gets certificate error [message #1821776 is a reply to message #1821771] |
Thu, 20 February 2020 05:12 |
Ed Merks Messages: 33140 Registered: July 2009 |
At a customer site recently I had endless problems like this. We finally got the network settings to communicate through the proxy (using manual settings) to make update sites accessible, but then EGit/JGit failed with exactly these same low level stack traces until I switched back to native settings... Here too we had to manually add the certificates (for the Git repository's site, and for some reason there were 3 we had to add) to Java's certificate store (and did so correctly), but via manual network settings (to use the proxy server), these somehow didn't work for JGit. I've also had problems like this testing all the marketplace listings locally on my machine, but it worked better on the build server. And yes, I think it's possible for root certificates to be removed but of course it's just so much voodoo...
Ed Merks
FUDForum. Page generated in 0.09019 seconds
