Home » Eclipse Projects » Kura » Channel subscription
Channel subscription [message #1821623] Mon, 17 February 2020 15:22 Go to next message
Pedro de Arquer is currently offline Pedro de ArquerFriend
Member
I'm working on a connection driver that is actually subscribed to a device. Is is a good approach to configure it as an asset? In case it is, I was thinking in take advantage of the listen property already available in the WireAsset but I'm not sure that it should be used for this purpose.
Re: Channel subscription [message #1821652 is a reply to message #1821623] Tue, 18 February 2020 08:20 Go to previous messageGo to next message
Matteo Maiero is currently offline Matteo MaieroFriend
what do you mean with "connection driver"?
Can you detail a little better what is the setup?
matteo
Re: Channel subscription [message #1821654 is a reply to message #1821652] Tue, 18 February 2020 09:03 Go to previous messageGo to next message
Member
I mean an implementation of org.eclipse.kura.driver.Driver. So far I've only created connections of type master-slave where I periodically request the data. What I intend to do is to perform a publish-subscribe connection with a device. Are the WireAsset and Driver interfaces the right option for this new approach? Is the field listen (of the ChannelRecords) expected to be used for this purpose?
[Updated on: Tue, 18 February 2020 09:04]
Report message to a moderator
Re: Channel subscription [message #1821655 is a reply to message #1821654] Tue, 18 February 2020 09:30 Go to previous message
An example of driver that can be used in listen mode is this one: https://github.com/eclipse/kura/tree/develop/kura/org.eclipse.kura.driver.ble.xdk
Previous Topic:Kura on raspberry pi3
Next Topic:Integration with Hawkbit
Current Time: Tue Jan 26 19:44:12 GMT 2021
Powered by FUDForum. Page generated in 0.01997 seconds
