Home » Newcomers » Newcomers » Eclipse Fails To Run(Eclipse not starting after launch.)
Eclipse Fails To Run [message #1820647] Fri, 24 January 2020 10:32 Go to next message
Saifullah Rahool is currently offline Saifullah RahoolFriend
Hi there, a Linux newbie here. My university recently asked us all to switch to Ubuntu for our programming courses and to use Eclipse as the IDE. So I recently installed Eclipse for C++ however, the program fails to launch. I'm providing the following info and maybe you can guide me on what to do.
index.php/fa/37227/0/
The log is also in the downloads.
Re: Eclipse Fails To Run [message #1820656 is a reply to message #1820647] Sat, 25 January 2020 06:44 Go to previous message
Nitin Dahyabhai is currently offline Nitin DahyabhaiFriend
You're using Java 11 to run Eclipse 4.7.3, which was released in early 2018. While it's possible to run that on Java 9 and 10 with some work, you'll need the 2018-12 release, or newer, to run under Java 11 (which was released in late 2018). I'd suggest the current, supported, release 2019-12 unless you have a strong reason to avoid it.
Nitin Dahyabhai
Eclipse Web Tools Platform
[Updated on: Sat, 25 January 2020 06:44]
Report message to a moderator
Previous Topic:Yet another new install
Next Topic:Runtime dependencies for jetty?
Current Time: Mon Oct 26 23:10:51 GMT 2020
Powered by FUDForum. Page generated in 0.02997 seconds
