Home » Polarsys » Capella Studio » Git adress(Where are the sources? )
Git adress [message #1820531] Wed, 22 January 2020 09:34 Go to next message
Jean Albrieux is currently offline Jean AlbrieuxFriend
Hello everybody,
I was using the following git adress to reach the sources:
git.polarsys.org/c/capella.git
But since a few days it is written "no repositories found".
As the forum has been moved recently, is it the same for the git repository?
In this case what is the new address?
Jean
Re: Git adress [message #1821209 is a reply to message #1820531] Fri, 07 February 2020 08:58 Go to previous messageGo to next message
Soulimane KAMNI is currently offline Soulimane KAMNIFriend
Dear Jean Albrieux,
I have had the exact same problem. After a long time of seaching, I could finally get the capella repository. You can access to it through the link hereafter.
Capella:
https://git.eclipse.org/c/?q=capella
I hope I could answer to your need.
Soulimane.
Re: Git adress [message #1821231 is a reply to message #1821209] Fri, 07 February 2020 14:27 Go to previous messageGo to next message
Stephane LACRAMPE is currently offline Stephane LACRAMPEFriend
The link to the sources from the Capella website download page has also been fixed.
Stephane
Stephane LACRAMPE
Obeo Canada
Re: Git adress [message #1822160 is a reply to message #1821231] Fri, 28 February 2020 09:46 Go to previous messageGo to next message
Stephan,
The link for capella repository in capella website leads still to the repository with the "no repository found" problem.
The link below leads to the repository that contains some capella plugins on github as well.
https://github.com/eclipse/capella
Soulimane
[Updated on: Fri, 28 February 2020 16:40]
Report message to a moderator
Re: Git adress [message #1822238 is a reply to message #1822160] Mon, 02 March 2020 09:50 Go to previous message
Benoit Langlois is currently offline Benoit LangloisFriend
Here is a summary after the migration to GitHub for the repositories, and from the PolarSys to Eclipse infrastructure for the CI:
- Capella / Git: https://github.com/eclipse/capella
- Capella / CI: https://ci.eclipse.org/capella/
- Capella Studio / Git: https://github.com/eclipse/capella-studio
- Capella Studio / CI: https://ci.eclipse.org/capella/view/Capella%20Studio/
Kind regards,
Benoit
Previous Topic:how can I open editor programmatically in Capella using the activity link
Next Topic:Capella studio java.lang.NoClassDefFoundError
Current Time: Tue Jul 05 07:49:01 GMT 2022
Powered by FUDForum. Page generated in 0.01352 seconds
