Visual Studio C++ compiler under Eclipse [message #1819708] |
Tue, 21 January 2020 13:10  |
Hello!
I'd like to use Eclipse, however my project has some external dependencies compiled in VS, and I just couldn't get it linked to GCC. Therefore, I would like to use the VS compiler under Eclipse.
I had problems since the beginning, but managed to specify the "include" folders so that there are no missing .h files. However, now I get a very dubious "cl : Command line error D8003 : missing source filename" error, which as far as I understood could be solved by changing the order of the arguments of cl.exe. I gave up after 1 hour of trying.
Is there a list of things I need to configure in order to this to work? Could someone give me some tips what to configure in Eclipse settings?
PS: I've seen another topic with the same problem, but it was from 2010, and it also didn't have any specifics on what to do.
FUDForum. Page generated in 0.24799 seconds
