Home » Newcomers » Newcomers » error when I lunch the eclipse rcp
error when I lunch the eclipse rcp [message #1819667] Mon, 20 January 2020 16:18 Go to next message
narges b is currently offline narges bFriend
Hi all,
when I lunching the application on eclipse RCP the result is this error :
!SESSION Mon Jan 20 16:47:51 CET 2020 ------------------------------------------
!ENTRY org.eclipse.equinox.launcher 4 0 2020-01-20 16:47:51.300
!MESSAGE Exception launching the Eclipse Platform:
!STACK
java.lang.ClassNotFoundException: org.eclipse.core.runtime.adaptor.EclipseStarter
at java.base/java.net.URLClassLoader.findClass(URLClassLoader.java:436)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:588)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:521)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:654)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:594)
at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
at org.eclipse.equinox.launcher.Main.main(Main.java:1438)
could you please help me to solve it? version of my esclipse is 2019-12 (laste version) and also I tri with JRE 8 and 13 ! but :(
thanks in advance for your help
Re: error when I lunch the eclipse rcp [message #1819678 is a reply to message #1819667] Tue, 21 January 2020 06:51 Go to previous messageGo to next message
This stack trace is not from trying to run with Java 8. I can tell because module names are in the stack trace. Does this same problem really happen when you launch with Java 8?
Ed Merks
Re: error when I lunch the eclipse rcp [message #1820541 is a reply to message #1819678] Wed, 22 January 2020 13:21 Go to previous messageGo to next message
I use java8 and also eclipse oxygen and solve the problem, yeah I think I have a problem with java.
thanks, and another question do you know how can I change the logo (when lunching and see Hello world Logo )?
*this logo that I uploaded.
  • Attachment: sc.jpg
    (Size: 37.22KB, Downloaded 91 times)
Re: error when I lunch the eclipse rcp [message #1820546 is a reply to message #1820541] Wed, 22 January 2020 14:03 Go to previous messageGo to next message
I'm not sure what type of application you're launching, but try Googling for "eclipse splash.bmp" to find some information about branding a product...
Ed Merks
Re: error when I lunch the eclipse rcp [message #1841280 is a reply to message #1819667] Tue, 11 May 2021 00:03 Go to previous messageGo to next message
Andre Oid is currently offline Andre OidFriend
hey guys, please i got the same issues i just installed eclipse and when i try launch it, that give me the following error:
!SESSION Mon May 10 23:53:34 GMT 2021 ------------------------------------------
!ENTRY org.eclipse.equinox.launcher 4 0 2021-05-10 23:53:34.862
!STACK
at java.base/java.net.URLClassLoader.findClass(URLClassLoader.java:471)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:589)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:522)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:626)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
here is my java version :
openjdk 11.0.11 2021-04-20
OpenJDK Runtime Environment (build 11.0.11+9-Ubuntu-0ubuntu2.18.04)
OpenJDK Server VM (build 11.0.11+9-Ubuntu-0ubuntu2.18.04, mixed mode, sharing)
pleazzzzzzzzzz
please help me there is a long time that i ride through the web with this explainable curse
as OS, i got Ubuntu 18.04
Re: error when I lunch the eclipse rcp [message #1841281 is a reply to message #1841280] Tue, 11 May 2021 00:52 Go to previous message
Nitin Dahyabhai is currently offline Nitin DahyabhaiFriend
You really should have made your own thread, Andre. Which version of Eclipse is it, and built by whom?
Nitin Dahyabhai
Eclipse Web Tools Platform
Previous Topic:How to use a variable in Python (2.x) to define decimal part?
Next Topic:oomph installer: checkstyle repo not found
Current Time: Tue Jul 05 04:06:49 GMT 2022
Powered by FUDForum. Page generated in 0.04331 seconds
