Home » Newcomers » Newcomers » Setting up new developer environment - 14k+ errors?(Is the default Oomph environment meant to work?)
Setting up new developer environment - 14k+ errors? [message #1819616] Sat, 18 January 2020 14:46 Go to next message
D Southwick is currently offline D SouthwickFriend
Beginner here - I'd like to try and follow your Hello World example, however using the most recent version of eclipse Oomph setup yields 14,790 errors on the default view, before clicking anything.
I attempted the very first step for the Hello World tutorial, but it seems the Automated dependency management / MANIFEST.MF is restricted to ONLY org.eclipse.kura.* plugins in your default Oomph profile.
Is this a problem with recent eclipse? is the tutorial simply way out of date?
What's the easiest way to resolve this? use eclipse from 2017?
As is pretty obvious, I'm not a java expert, so this seems like a pretty big hurdle to debug just to get the basic tutorial tools to start the tutorial. Help ?
Re: Setting up new developer environment - 14k+ errors? [message #1819628 is a reply to message #1819616] Sun, 19 January 2020 06:41 Go to previous messageGo to next message
Sorry, I'm not sure exactly what you tried and did. The installer's simple mode only creates an installation, not a workspace. Perhaps you switched to advanced model and used one of the various project setups as well, but those are not for "Hello World" examples; those are setups of various Eclipse projects that will be entirely focused on developing the source code for those projects. If you want to start working on Java as a beginner, install just the Eclipse IDE for Java Developers, start with an empty workspace, and Google for a good introductory for Eclipse Java tutorial.
Ed Merks
Re: Setting up new developer environment - 14k+ errors? [message #1819631 is a reply to message #1819628] Sun, 19 January 2020 10:20 Go to previous message
gah - sorry this is meant for eclipse Kura - I realised after I clicked submit that I cannot edit until it came out of moderation. :(
Previous Topic:How are licenses enforced on products built on eclipse
Next Topic:Eclipse IDE for C++ - Silent / Unattended install
Current Time: Tue Oct 27 19:29:44 GMT 2020
Powered by FUDForum. Page generated in 0.03708 seconds
