Home » Polarsys » Capella workbench » Capella Project versus Capella Library
Capella Project versus Capella Library [message #1819429] Wed, 15 January 2020 10:02 Go to next message
Mathias Cocheri is currently offline Mathias CocheriFriend
I'm a little bit confused regarding the difference between libraries and projects in Capella.
So far, the only differences I noticed are:
- Project can reference and use libraries
- Libraries can reference and use other libraries
- Project cannot be used as a reference for other project or libraries
In the tool itself, I didn't noticed anything in particular that would be available in a project and not in a library.
Thus, currently it seems to me that Libraries are actually more flexible while providing the same level of features in Capella than projects. If the system you are describing could potentially be part of a bigger picture in a few years, one may want to create a library instead of a project as there is no specific drawbacks afaik.
-> Is there any advantages to create project instead of libraries ?
Re: Capella Project versus Capella Library [message #1820630 is a reply to message #1819429] Fri, 24 January 2020 03:33 Go to previous messageGo to next message
Stephane LACRAMPE is currently offline Stephane LACRAMPEFriend
Member
Hi Matthias,
I believe there are no advantages on projects over libraries.
Stephane
Obeo
Stephane LACRAMPE
Obeo Canada
Re: Capella Project versus Capella Library [message #1822179 is a reply to message #1820630] Fri, 28 February 2020 20:28 Go to previous messageGo to next message
Scott Millsap is currently offline Scott MillsapFriend
Be careful about Capella Libraries. Today for the first time, I tried to transition logical level elements to the physical architecture phase but could not get the transition to complete. I wasn't trying the process any different than I have done within a Capella project. I probed around the Capella preferences to see if a configuration needed to be changed but nothing was obvious to me. If a Capella Library does not allow for this operation then that is a major reason to not use them in place of a regular Capella project.
Re: Capella Project versus Capella Library [message #1822181 is a reply to message #1822179] Fri, 28 February 2020 21:59 Go to previous message
Member
Hi Scott,
Good point, actually this is a regression in Capella 1.3.1 and Capella 1.4.0, it will be fixed in Capella 1.3.2 and Capella 1.4.1, more information here:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=555485
Stephane LACRAMPE
Obeo
Stephane LACRAMPE
Obeo Canada
Previous Topic:Node & Behavior PC Relationships
Next Topic:Physical components issues
Current Time: Wed Apr 01 22:26:56 GMT 2020
Powered by FUDForum. Page generated in 0.05279 seconds
