Home » Polarsys » Capella workbench » Capella Project versus Capella Library
Capella Project versus Capella Library [message #1819429] Wed, 15 January 2020 05:02 Go to next message
I'm a little bit confused regarding the difference between libraries and projects in Capella.
So far, the only differences I noticed are:
- Project can reference and use libraries
- Libraries can reference and use other libraries
- Project cannot be used as a reference for other project or libraries
In the tool itself, I didn't noticed anything in particular that would be available in a project and not in a library.
Thus, currently it seems to me that Libraries are actually more flexible while providing the same level of features in Capella than projects. If the system you are describing could potentially be part of a bigger picture in a few years, one may want to create a library instead of a project as there is no specific drawbacks afaik.
-> Is there any advantages to create project instead of libraries ?
Re: Capella Project versus Capella Library [message #1820630 is a reply to message #1819429] Thu, 23 January 2020 22:33 Go to previous messageGo to next message
Hi Matthias,
I believe there are no advantages on projects over libraries.
Stephane
Obeo
Re: Capella Project versus Capella Library [message #1822179 is a reply to message #1820630] Fri, 28 February 2020 15:28 Go to previous messageGo to next message
Be careful about Capella Libraries. Today for the first time, I tried to transition logical level elements to the physical architecture phase but could not get the transition to complete. I wasn't trying the process any different than I have done within a Capella project. I probed around the Capella preferences to see if a configuration needed to be changed but nothing was obvious to me. If a Capella Library does not allow for this operation then that is a major reason to not use them in place of a regular Capella project.
Re: Capella Project versus Capella Library [message #1822181 is a reply to message #1822179] Fri, 28 February 2020 16:59 Go to previous messageGo to next message
Hi Scott,
Good point, actually this is a regression in Capella 1.3.1 and Capella 1.4.0, it will be fixed in Capella 1.3.2 and Capella 1.4.1, more information here:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=555485
Stephane LACRAMPE
Obeo
Re: Capella Project versus Capella Library [message #1823807 is a reply to message #1822181] Thu, 02 April 2020 06:33 Go to previous messageGo to next message
I found a bug that may be related to https://bugs.eclipse.org/bugs/show_bug.cgi?id=555485
In short: if the function ports (FP) or functionnal exchanges (FE) have exchanged items (EI) coming from a library, the transition from LA to PA does not work.
In the example attached, if you remove the EI coming from the library, the transition complete sucessfully. Otherwise, it does not complete (but did not openned in debug mode to see log output.
Can you confirm if 555485 solve the issue ?
Is there a release-candidate we can download now that solve the issue ?
Thank you.
Re: Capella Project versus Capella Library [message #1823810 is a reply to message #1823807] Thu, 02 April 2020 07:46 Go to previous messageGo to next message
Not fixed with version capella-1.4.1.202003251617
I opened a bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=561689
Re: Capella Project versus Capella Library [message #1823844 is a reply to message #1823810] Thu, 02 April 2020 17:27 Go to previous messageGo to next message
555485 is solved in 1.3.2 and in upcoming 1.4.1.
561689 occurs when a library is created without Operational Analysis.
Re: Capella Project versus Capella Library [message #1824135 is a reply to message #1823844] Wed, 08 April 2020 08:34 Go to previous message
Thank you for your answer.
Indeed I will take a better look at information view.
Previous Topic:Contextually create new systems actors from OE/Actors
Next Topic:Transition problem
Current Time: Sun Nov 02 05:04:55 EST 2025
Powered by FUDForum. Page generated in 0.06511 seconds
