Home » Newcomers » Newcomers » Eclipse Reports (BIRT) Chart FAILED_TO_CREATE_INSTANCE(Error when using Eclipse Reports)
Eclipse Reports (BIRT) Chart FAILED_TO_CREATE_INSTANCE [message #1818860] Mon, 30 December 2019 19:33 Go to next message
Nils Mork is currently offline Nils MorkFriend
I have recently installed Eclipse Reports December 2018 version, using OPENJDK 1.8.0.222 runtime. I can generate tabular reports with no problems. However, I am getting an error when trying to create a chart report.
The example is attached. The report uses a flat file data source.
When I run debug, I get the below error:
Dec 30, 2019 11:12:10 AM org.eclipse.birt.report.debug.internal.core.vm.ReportVMServer start
INFO: [Server] client accepted
Dec 30, 2019 11:12:10 AM org.eclipse.birt.report.debug.internal.core.vm.ReportVMServer$1 run
INFO: [Server] enter request dispatching
Dec 30, 2019 11:12:10 AM org.eclipse.birt.report.debug.internal.core.launcher.ReportLauncher configEngine
INFO: User class path received:
Dec 30, 2019 11:12:11 AM org.eclipse.birt.report.model.metadata.ExtensionLoader handleError
SEVERE: Message:The class [org.eclipse.birt.chart.reportitem.ChartReportItemFactoryImpl] can not be instantiated. Error code:FAILED_TO_CREATE_INSTANCE
SEVERE: Message:The class [org.eclipse.birt.chart.reportitem.ChartScriptableClassInfo] can not be instantiated. Error code:FAILED_TO_CREATE_INSTANCE
Dec 30, 2019 11:12:12 AM org.eclipse.birt.report.engine.extension.internal.ExtensionManager createObject
WARNING: Can not instantiate class org.eclipse.birt.chart.reportitem.ChartReportItemQueryImpl with property class.
WARNING: Can not instantiate class org.eclipse.birt.chart.reportitem.ChartReportItemGenerationProxy with property class.
Dec 30, 2019 11:12:12 AM org.eclipse.birt.report.engine.extension.internal.ExtensionManager createReportItemExecutor
WARNING: Create Report Item Executor fail, Config not exist class: reportItem
>>>> Compiled Source: unnamed script
row["Hour"].substring(9,18)
>>>> end compilation.
row["Hour"].substring(0,4)+"-"+row["Hour"].substring(4,6)+"-"+row["Hour"].substring(6,8)
>>>> end compilation.
WARNING: Can not instantiate class org.eclipse.birt.chart.reportitem.ChartReportItemPresentationProxy with property class.
Dec 30, 2019 11:12:12 AM org.eclipse.birt.report.engine.api.impl.EngineTask handleFatalExceptions
SEVERE: An error happened while running the report. Cause:
at org.eclipse.birt.report.engine.presentation.LocalizedContentVisitor.processExtendedContent(LocalizedContentVisitor.java:1006)
at org.eclipse.birt.report.engine.presentation.LocalizedContentVisitor.localizeForeign(LocalizedContentVisitor.java:602)
at org.eclipse.birt.report.engine.presentation.LocalizedContentVisitor.localize(LocalizedContentVisitor.java:176)
at org.eclipse.birt.report.engine.internal.executor.l18n.LocalizedReportItemExecutor.execute(LocalizedReportItemExecutor.java:37)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:65)
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout(HTMLPageLM.java:92)
at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutEngine.layout(HTMLReportLayoutEngine.java:100)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:181)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run(RunAndRenderTask.java:77)
at org.eclipse.birt.report.debug.internal.core.launcher.ReportLauncher.createReport(ReportLauncher.java:620)
at org.eclipse.birt.report.debug.internal.core.launcher.ReportLauncher.renderReport(ReportLauncher.java:566)
at org.eclipse.birt.report.debug.internal.core.launcher.ReportLauncher.run(ReportLauncher.java:480)
at org.eclipse.birt.report.debug.internal.core.launcher.ReportLauncher.main(ReportLauncher.java:124)
at org.eclipse.birt.report.debug.internal.core.ReportDebugger.start(ReportDebugger.java:39)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:137)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:107)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:400)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:659)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:595)
at org.eclipse.equinox.launcher.Main.run(Main.java:1501)
at org.eclipse.equinox.launcher.Main.main(Main.java:1474)
Dec 30, 2019 11:12:12 AM org.eclipse.birt.report.debug.internal.core.launcher.ReportLauncher renderReport
SEVERE: Engine exception
org.eclipse.birt.report.engine.api.EngineException: Error happened while running the report.
at org.eclipse.birt.report.engine.api.impl.EngineTask.handleFatalExceptions(EngineTask.java:2379)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:191)
... 19 more
Dec 30, 2019 11:12:12 AM org.eclipse.birt.report.debug.internal.core.vm.ReportVMServer$1 run
WARNING: [Server] client disconnected
Re: Eclipse Reports (BIRT) Chart FAILED_TO_CREATE_INSTANCE [message #1818864 is a reply to message #1818860] Tue, 31 December 2019 05:32 Go to previous messageGo to next message
It's best to ask on the BIRT forum:
https://www.eclipse.org/forums/index.php?t=thread&frm_id=2
Or open a bug report:
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=BIRT
There are many open though, so I'm not hopeful you'll get much response unless you contribute the fix.
https://bugs.eclipse.org/bugs/buglist.cgi?bug_status=UNCONFIRMED&bug_status=NEW&bug_status=ASSIGNED&bug_status=REOPENED&classification=Technology&order=bug_id%20DESC&product=BIRT&query_format=advanced
Re: Eclipse Reports (BIRT) Chart FAILED_TO_CREATE_INSTANCE [message #1818879 is a reply to message #1818864] Tue, 31 December 2019 14:24 Go to previous messageGo to next message
Thanks for the reply. I think it might be something missing from the Eclipse IDE setup--since I only plan to use the IDE for BIRT & I only installed Eclipse Reporting, are there steps missing from the environment setup?
OS: Windows 10
CLASSPATH: not set (seemed like it was working without one--tables, crosstabs, etc., are generated)
Workspace directory is not the same as default which shows in the IDE startup dialog, also, I seem to always need to open the debug perspective to set output directories for report debugging (not saving the information?) And no default viewer(s) seem to launch and no apparent way to set all of these things up.
Re: Eclipse Reports (BIRT) Chart FAILED_TO_CREATE_INSTANCE [message #1818880 is a reply to message #1818879] Tue, 31 December 2019 14:40 Go to previous messageGo to next message
Strangely. I found a posting on Stack overflow for a COMPLETELY DIFFERENT issue which recommended running
eclipse -clean
to solve the problem. I tried that to see if this solved the problem, and suddenly the chart appears! No more errors (at least for today.) Mysterious-er and mysterious-er. Any detailed information on what the -clean option does, specifically?
Re: Eclipse Reports (BIRT) Chart FAILED_TO_CREATE_INSTANCE [message #1818898 is a reply to message #1818880] Wed, 01 January 2020 08:31 Go to previous message
It does this:
https://help.eclipse.org/2019-09/index.jsp?topic=%2Forg.eclipse.platform.doc.isv%2Freference%2Fmisc%2Fruntime-options.html&anchor=osgiclean
So it essentially does a bunch of work to reinitialize all the dependencies between all the plug-ins. Normally that happens automatically the first time you run or after installing new software (or updating) and restarting...
Previous Topic:Saving export filename per project?
Next Topic:Mosquitto
Current Time: Sat Feb 22 14:14:14 GMT 2020
Powered by FUDForum. Page generated in 0.03959 seconds
