Home » Language IDEs » Java Development Tools (JDT) » Text disappears in editor as it is being written(When a line is edited in the editor, it disappears for about a second and then (usually) re-appears)
Text disappears in editor as it is being written [message #1818797] Sun, 29 December 2019 03:39
Craig Cox is currently offline Craig CoxFriend
I have just installed Eclipse IDE for Java Developers, Version: 2019-09 R (4.13.0), Build id: 20190917-1200. I have an issue with the editor when I type text into any type of text file (e.g., *.java, *.txt). As I type characters, the entire line I am editing will disappear (change to the background color) for a second or so. If I type at a normal speed (more than one character per second), the line stays hidden until about a second after I stop typing. Usually, although occasionally the line stays hidden even after the second passes. The line always re-appears if I mouse-click on a different line, or if I hit Print-Screen to try to get screen shots. I was able to get some delayed action screen shots that show the results.
In image 1, I need to add a semi-colon at the end of a line. In image 2, I have hit the semi-colon key, and the entire line disappears (and is replaced by the background color). In image 3, about a second has passed and the semi-colon (and remainder of the line) has re-appeared.
Initially I thought that this was an issue with my NVIDIA drivers, but the same behavior occurs when I run using my on-board Intel video chip. In the screenshots I have vwrapper installed but the issue occurs even after I uninstalled vwrapper and re-started. It occurs whether Smart Line Insert is enabled or notHas anyone seen this behavior and have any suggestions on how to resolve it?
Here are the outputs of some commands showing my setup. What other listings would be useful?
$ cat /etc/lsb-release
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=16.04
DISTRIB_CODENAME=xenial
DISTRIB_DESCRIPTION="Ubuntu 16.04.6 LTS"
$ uname -a
Linux cr38 4.15.0-72-generic #81~16.04.1-Ubuntu SMP Tue Nov 26 16:34:21 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
$ lspci
00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v6/7th Gen Core Processor Host Bridge/DRAM Registers (rev 02)
00:02.0 VGA compatible controller: Intel Corporation HD Graphics 620 (rev 02)
00:14.0 USB controller: Intel Corporation Sunrise Point-LP USB 3.0 xHCI Controller (rev 21)
00:14.2 Signal processing controller: Intel Corporation Sunrise Point-LP Thermal subsystem (rev 21)
00:15.0 Signal processing controller: Intel Corporation Sunrise Point-LP Serial IO I2C Controller #0 (rev 21)
00:15.1 Signal processing controller: Intel Corporation Sunrise Point-LP Serial IO I2C Controller #1 (rev 21)
00:16.0 Communication controller: Intel Corporation Sunrise Point-LP CSME HECI #1 (rev 21)
00:17.0 SATA controller: Intel Corporation Sunrise Point-LP SATA Controller [AHCI mode] (rev 21)
00:1c.0 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #1 (rev f1)
00:1d.0 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #9 (rev f1)
00:1d.3 PCI bridge: Intel Corporation Device 9d1b (rev f1)
00:1f.0 ISA bridge: Intel Corporation Sunrise Point-LP LPC Controller (rev 21)
00:1f.2 Memory controller: Intel Corporation Sunrise Point-LP PMC (rev 21)
00:1f.3 Audio device: Intel Corporation Sunrise Point-LP HD Audio (rev 21)
00:1f.4 SMBus: Intel Corporation Sunrise Point-LP SMBus (rev 21)
01:00.0 3D controller: NVIDIA Corporation GM108M [GeForce 940MX] (rev ff)
03:00.0 Network controller: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter (rev 32)
$ lspci -v
Subsystem: Acer Incorporated [ALI] Device 112e
Flags: bus master, fast devsel, latency 0
Capabilities: <access denied>
Kernel driver in use: skl_uncore
00:02.0 VGA compatible controller: Intel Corporation HD Graphics 620 (rev 02) (prog-if 00 [VGA controller])
Flags: bus master, fast devsel, latency 0, IRQ 127
Memory at a2000000 (64-bit, non-prefetchable) [size=16M]
Memory at b0000000 (64-bit, prefetchable) [size=256M]
I/O ports at 4000 [size=64]
[virtual] Expansion ROM at 000c0000 [disabled] [size=128K]
Kernel driver in use: i915
Kernel modules: i915
00:14.0 USB controller: Intel Corporation Sunrise Point-LP USB 3.0 xHCI Controller (rev 21) (prog-if 30 [XHCI])
Subsystem: Acer Incorporated [ALI] Sunrise Point-LP USB 3.0 xHCI Controller
Flags: bus master, medium devsel, latency 0, IRQ 125
Memory at a4200000 (64-bit, non-prefetchable) [size=64K]
Kernel driver in use: xhci_hcd
Subsystem: Acer Incorporated [ALI] Sunrise Point-LP Thermal subsystem
Flags: bus master, fast devsel, latency 0, IRQ 18
Memory at a422a000 (64-bit, non-prefetchable) [size=4K]
Kernel driver in use: intel_pch_thermal
Kernel modules: intel_pch_thermal
Subsystem: Acer Incorporated [ALI] Sunrise Point-LP Serial IO I2C Controller
Flags: bus master, fast devsel, latency 0, IRQ 16
Memory at a422b000 (64-bit, non-prefetchable) [size=4K]
Kernel driver in use: intel-lpss
Kernel modules: intel_lpss_pci
Flags: bus master, fast devsel, latency 0, IRQ 17
Memory at a422c000 (64-bit, non-prefetchable) [size=4K]
Subsystem: Acer Incorporated [ALI] Sunrise Point-LP CSME HECI
Flags: bus master, fast devsel, latency 0, IRQ 128
Memory at a422d000 (64-bit, non-prefetchable) [size=4K]
Kernel driver in use: mei_me
Kernel modules: mei_me
00:17.0 SATA controller: Intel Corporation Sunrise Point-LP SATA Controller [AHCI mode] (rev 21) (prog-if 01 [AHCI 1.0])
Subsystem: Acer Incorporated [ALI] Sunrise Point-LP SATA Controller [AHCI mode]
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 126
Memory at a4228000 (32-bit, non-prefetchable) [size=8K]
Memory at a4230000 (32-bit, non-prefetchable) [size=256]
I/O ports at 4080 [size=8]
I/O ports at 4088 [size=4]
I/O ports at 4060 [size=32]
Memory at a422e000 (32-bit, non-prefetchable) [size=2K]
Kernel driver in use: ahci
Kernel modules: ahci
00:1c.0 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #1 (rev f1) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 122
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 00003000-00003fff
Memory behind bridge: a3000000-a3ffffff
Prefetchable memory behind bridge: 0000000090000000-00000000a1ffffff
Kernel driver in use: pcieport
Kernel modules: shpchp
00:1d.0 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #9 (rev f1) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 123
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
00:1d.3 PCI bridge: Intel Corporation Device 9d1b (rev f1) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 124
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
Memory behind bridge: a4000000-a41fffff
Subsystem: Acer Incorporated [ALI] Sunrise Point-LP PMC
Memory at a4224000 (32-bit, non-prefetchable) [size=16K]
Flags: bus master, fast devsel, latency 32, IRQ 130
Memory at a4220000 (64-bit, non-prefetchable) [size=16K]
Memory at a4210000 (64-bit, non-prefetchable) [size=64K]
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel, snd_soc_skl
Subsystem: Acer Incorporated [ALI] Sunrise Point-LP SMBus
Flags: medium devsel, IRQ 255
Memory at a422f000 (64-bit, non-prefetchable) [size=256]
I/O ports at 4040 [size=32]
Kernel modules: i2c_i801
01:00.0 3D controller: NVIDIA Corporation GM108M [GeForce 940MX] (rev ff) (prog-if ff)
!!! Unknown header type 7f
Kernel modules: nvidiafb, nouveau, nvidia_384_drm, nvidia_384
Subsystem: Lite-On Communications Inc QCA6174 802.11ac Wireless Network Adapter
Flags: bus master, fast devsel, latency 0, IRQ 129
Memory at a4000000 (64-bit, non-prefetchable) [size=2M]
Kernel driver in use: ath10k_pci
Kernel modules: ath10k_pci
  • Attachment: 1.png
    (Size: 185.55KB, Downloaded 20 times)
  • Attachment: 2.png
    (Size: 182.05KB, Downloaded 14 times)
  • Attachment: 3.png
    (Size: 184.03KB, Downloaded 16 times)
Previous Topic:Eclipse on Java 13 vs Annotations
Next Topic:Postfix completion not work
Current Time: Tue Nov 24 20:32:37 GMT 2020
Powered by FUDForum. Page generated in 0.01751 seconds
