Re: Eclipse Installation issues. [message #1818780 is a reply to message #1818771] |
Sat, 28 December 2019 07:01 |
Ed Merks Messages: 33137 Registered: July 2009 |
Did you try the Configure Network Proxy... button? Typically even a Browser will require you to configure the way the network is accessed and it should be possible to configure the installer the same way. And note that this does not involve reconfiguring your actual network but rather entering the information needed to access the network through the proxy.
Also note that the installer will copy these network settings to the installation it creates. If you can't get the installer configured to work, then even the package you download (via a Browser that you must have configured to access the network through the proxy) and unzip will also not have network access so you won't be able to update or install new software in that IDE, which will also be very annoying.
Ed Merks
FUDForum. Page generated in 0.03886 seconds
