Home » Eclipse Projects » NatTable » NPE while saving State (with Filters
NPE while saving State (with Filters [message #1818752] Fri, 27 December 2019 07:24 Go to next message
Ludwig Moser is currently offline Ludwig MoserFriend
i am experiencing a NPE when i try to save the state of a Nattable.
i have a filter set then call
Properties properties = new Properties();
natTable.saveState("test", properties);
i am using version 1.6 of NatTable
with sorting, filter, grouping etc...
can you reproduce this issue? if not how can i find out whats causing this?
	at org.eclipse.nebula.widgets.nattable.filterrow.FilterRowDataProvider.getFilterStringRepresentation(FilterRowDataProvider.java:273)
	at org.eclipse.nebula.widgets.nattable.filterrow.FilterRowDataProvider.saveState(FilterRowDataProvider.java:201)
	at org.eclipse.nebula.widgets.nattable.layer.AbstractLayer.saveState(AbstractLayer.java:131)
	at org.eclipse.nebula.widgets.nattable.layer.DataLayer.saveState(DataLayer.java:90)
	at org.eclipse.nebula.widgets.nattable.layer.CompositeLayer.saveState(CompositeLayer.java:94)
	at org.eclipse.nebula.widgets.nattable.layer.AbstractLayerTransform.saveState(AbstractLayerTransform.java:70)
	at org.eclipse.nebula.widgets.nattable.NatTable$9.run(NatTable.java:785)
	at org.eclipse.nebula.widgets.nattable.NatTable.saveState(NatTable.java:781)
Re: NPE while saving State (with Filters [message #1818754 is a reply to message #1818752] Fri, 27 December 2019 08:06 Go to previous messageGo to next message
Dirk Fauth is currently offline Dirk FauthFriend
Typically by debugging and checking the sources
It seems to be because there is no converter for the column. Not sure if this is a regression or was always like this. But a NPE is always a bug, so please create a ticket.
Re: NPE while saving State (with Filters [message #1818755 is a reply to message #1818754] Fri, 27 December 2019 09:35 Go to previous messageGo to next message
well i tested on a text column - which should not need any converters -> so a default Converter that simply calls Object.toString() would be enough
ticket created: https://bugs.eclipse.org/bugs/show_bug.cgi?id=558643
[Updated on: Fri, 27 December 2019 09:54]
Report message to a moderator
Re: NPE while saving State (with Filters [message #1818756 is a reply to message #1818755] Fri, 27 December 2019 09:42 Go to previous messageGo to next message
Like said before it could be a regression. Need to check in more detail.
Please create a ticket so I don't forget to check.
Re: NPE while saving State (with Filters [message #1818762 is a reply to message #1818756] Fri, 27 December 2019 16:20 Go to previous messageGo to next message
Re: NPE while saving State (with Filters [message #1818768 is a reply to message #1818762] Fri, 27 December 2019 18:41 Go to previous messageGo to next message
OK, this is not a regression. That code exists for years without a reported issue.
My best guess is that you are not using the DefaultNatTableStyleConfiguration and additionally have not registered the necessary basic default configurations. One configuration is the DefaultDisplayConverter that is registered without a DisplayMode and without a label, which means it is used as fallback if nothing else is registered.
        configRegistry.registerConfigAttribute(
                CellConfigAttributes.DISPLAY_CONVERTER,
                new DefaultDisplayConverter());
If that configuration is missing it can happen that NPEs occur where a display converter is expected.
That said, of course a NPE is a programming error that needs to be fixed. But if you have the basic configuration correctly applied, it should never happen. So the criticality is low, but I will have a look.
You can fix this simply by adding the above configuration.
Re: NPE while saving State (with Filters [message #1818783 is a reply to message #1818768] Sat, 28 December 2019 07:53 Go to previous message
Dirk Fauth wrote on Fri, 27 December 2019 13:41
Thanks Dirk, this fixed the issue!
Previous Topic:how to create a custom filter
Next Topic:Instances of NatTable are beeing kept in memory after composite is disposed
Current Time: Thu Aug 05 00:48:32 GMT 2021
Powered by FUDForum. Page generated in 0.01899 seconds
