Nattable saveState and loadState issue [message #1818629] |
Fri, 20 December 2019 18:45 |
Ludwig Moser Messages: 476 Registered: July 2009 |
i ran into problems when storing settings for nattable
Description of my problem:
as far as i understand NatTable stores configs with index of the column as key.
this does not work for me as its possible that those indexes change with updates for my application (added fields - see below)
this is nattable specific and ok -> i need to write my own saveState.
how does nattable store the width of a column (its not in the properties file - is it?) i was not able to find this in the saveState - properties (did i miss it? and its there?)
further
when i change the config of the table (add columns -> indizes change) so the config is corrupted - wrong columns pop up, reordering is corrupt or nothing gets shown up at all (as mentioned above - this is no blame on nattable - as i do change the column count!)
finally to come to my question:
how can i get and get the width for columns?
EDIT: is it this: BODY.NONFROZEN_REGION.columnWidth.sizes=902\:38,928\:335,
column#902=38, only non defaults are saved?
how can i get and set the width for columns?
is there a command for setting multiple/all widths?
EDIT: so the simplest way would be patching the "properties"
[Updated on: Fri, 20 December 2019 18:49] Report message to a moderator
FUDForum. Page generated in 0.04442 seconds
