Saving export filename per project? [message #1818561] |
Thu, 19 December 2019 11:14  |
Hi. I find it rather annoying that Eclipse will just use the last path/filename when I export a jar file. I closed one project, opened another and worked on it for a bit then it's like muscle memory, I do the keyboard actions to export a jar too fast sometimes and do not notice the wrong jar is set so I end up overwriting something. Then I have to open the other project, re-export it then close and go back to what I was working on and export it properly.
Yes, I'm the problem because I'm moving too fast but I was really, really hoping maybe there was a setting or something in Eclipse to have it remember the path/filename when I export and recall it, specific to the project, the next time I export...?
Re: Saving export filename per project? [message #1818807 is a reply to message #1818561] |
Sun, 29 December 2019 12:34  |
Ken Nischan wrote on Thu, 19 December 2019 16:14Hi. I find it rather annoying that Eclipse will just use the last path/filename when I export a jar file. I closed one project, opened another site and worked on it for a bit then it's like muscle memory, I do the keyboard actions to export a jar too fast sometimes and do not notice the wrong jar is set so I end up overwriting something. Then I have to open the other project, re-export it then close and go back to what I was working on and export it properly.
If I'm not mistaken, there are no settings for this, you just need to work from the right project for a specific subtask.
FUDForum. Page generated in 0.08196 seconds
