Home » Eclipse Projects » Eclipse Platform » Need to "Close / Open project" - after EACH edit ( CDT ) !
Need to "Close / Open project" - after EACH edit ( CDT ) ! [message #1818344] Fri, 13 December 2019 03:12 Go to next message
Helen Keller is currently offline Helen KellerFriend
Since I have been experiencing this issue off and on for years(!) I feel an urge to share.
I do not expect solution , perhaps the usual "post bug " or "post this somewhere else".
I have a large C++ project under construction.
It has became very annoying to have to do AFTER each edit
"save all"
Build Project ( no need to "Refresh")
Run as TCF configuration
The ONLY "automation" I have figured out is "Refresh". It actually works ALL the time!
The "save before build" does not work - apparently TCF is not included .
Re: Need to "Close / Open project" - after EACH edit ( CDT ) ! [message #1818352 is a reply to message #1818344] Fri, 13 December 2019 09:02 Go to previous message
Rolf Theunissen is currently offline Rolf TheunissenFriend
Are the files not being saved in different projects? Then you are probably suffering from https://bugs.eclipse.org/bugs/show_bug.cgi?id=355984
If so, please update the bug according to the instructions in the last comment of it.
Previous Topic:workspaceRoot.getFile() does not return
Next Topic:No PerspectiveBarManager class in RCP Project Eclipse12
Current Time: Thu Sep 24 20:07:36 GMT 2020
Powered by FUDForum. Page generated in 0.02350 seconds
