Home » Eclipse Projects » P2 » Eclipse Install on Citrix Xenapp(Error when launching Eclipse on Citrix after installing as administrator)
Eclipse Install on Citrix Xenapp [message #1818337] Thu, 12 December 2019 17:59 Go to next message
Lucas Pires is currently offline Lucas PiresFriend
Hi guys,
I have installed Eclipse as administrator on a Citrix Server machine and it works fine. But when other users log on to that machine and try to open Eclipse, they get this error: "The Eclipse executable launcher was unable to locate its companion shared library".
Does anybody can give any help with the above?
Re: Eclipse Install on Citrix Xenapp [message #1826678 is a reply to message #1818337] Tue, 28 April 2020 17:07 Go to previous messageGo to next message
Raj Anumalasetty is currently offline Raj AnumalasettyFriend
Hi Lucas,
Is your issue solved? I am looking for solution for the same error.
Re: Eclipse Install on Citrix Xenapp [message #1841506 is a reply to message #1826678] Wed, 19 May 2021 10:43 Go to previous message
Shayan Bokhari is currently offline Shayan BokhariFriend
Hi Guys,
did you resolve this? i'm also getting the same error.
thanks
Previous Topic:Run uninstall action on restart
Next Topic:No repository found message
Current Time: Sat Dec 07 09:41:02 GMT 2024
Powered by FUDForum. Page generated in 0.03303 seconds
