Home » Language IDEs » C / C++ IDE (CDT) » eclipse script runing problem(runing a component.mk file when compiling the program.)
eclipse script runing problem [message #1817907] Mon, 02 December 2019 18:19 Go to next message
hello
i am working on an ESP32 program using eclipse and ESP-IDF.
i have a file named component.mk which contains a script that create a heder for keys to connect to AWS platform.
here is the script form:
COMPONENT_EXTRA_CLEAN := certs.h
main.o: certs.h
certs.h: $(COMPONENT_PATH)/certs/root-CA.crt $(COMPONENT_PATH)/certs/certificate.pem.crt $(COMPONENT_PATH)/certs/private.pem.key
$(Q) rm -f certs.h
$(Q) echo "const char *rootCA =" >> certs.h
$(Q) cat $(COMPONENT_PATH)/certs/root-CA.crt | tr -d "\r" | awk '{ print "\""$$0"\\r\\n\""}' >> certs.h
$(Q) echo ";" >> certs.h
$(Q) echo "const char *devicePrivateKey =" >> certs.h
$(Q) cat $(COMPONENT_PATH)/certs/private.pem.key | tr -d "\r" | awk '{ print "\""$$0"\\r\\n\""}' >> certs.h
$(Q) echo "const char *deviceCert =" >> certs.h
$(Q) cat $(COMPONENT_PATH)/certs/certificate.pem.crt | tr -d "\r" | awk '{ print "\""$$0"\\r\\n\""}' >> certs.h
is there a maner to run this script while compiling the program.
regards.
Zakaria.
Re: eclipse script runing problem [message #1817989 is a reply to message #1817907] Tue, 03 December 2019 18:33 Go to previous messageGo to next message
The script should be run by make.
Put it somewhere and run in a terminal window.
make -f component.mk
Be aware that it requires at least COMPONENT_PATH to be defined.
Apparently to the base directory containing the .crt and .key files.
You could include it in your build makefile but only if your project is a Makefile project.
Meaning you control the makefile.
Re: eclipse script runing problem [message #1818020 is a reply to message #1817907] Wed, 04 December 2019 05:18 Go to previous message
hello David
thanks for the help.
i managed to run it with make.
regards.
Zakaria
Previous Topic:How to use CDT to create a .h with a class decl?
Next Topic: How to open/import Arduino IDE's into Eclipse
Current Time: Sat Nov 01 23:37:40 EDT 2025
Powered by FUDForum. Page generated in 0.03539 seconds
