Home » Eclipse Projects » Linux Tools Project » gmon.out generated on target board is failing due to EOF Exception while visualizing in Eclipse GPRO(GPROF Viewer gmon.out error )
gmon.out generated on target board is failing due to EOF Exception while visualizing in Eclipse GPRO [message #1817782] Fri, 29 November 2019 05:10 Go to next message
Bhushan Ivatury is currently offline Bhushan IvaturyFriend
Hello
We are using the riscv-gnu-toolchain and used -pg to do the profiling on the remote target board . The gmon.out is produced but its not been able to visualize in the Eclipse Linuxtools GPROF viewer plugin.
The viewer throws an end of file exception while decoding the histogram.
The same gmon.out was able to generate output using gprof2dot using graphviz
Attached is the gmon.out and output from gprof2dot.
The OS on which Eclipse is installed is Ubuntu 19.x
Target is a RISCV board.
The error occurred is below.
!ENTRY org.eclipse.linuxtools.gprof 4 4 2019-11-25 18:00:55.663
!MESSAGE
!STACK 0
java.io.EOFException
at java.base/java.io.DataInputStream.readFully(DataInputStream.java:202)
at org.eclipse.linuxtools.internal.gprof.utils.LEDataInputStream.readShort(LEDataInputStream.java:40)
at org.eclipse.linuxtools.internal.gprof.parser.HistogramDecoder.decodeHistRecord(HistogramDecoder.java:183)
at org.eclipse.linuxtools.internal.gprof.parser.GmonDecoder.readGmonContent(GmonDecoder.java:195)
at org.eclipse.linuxtools.internal.gprof.parser.GmonDecoder.read(GmonDecoder.java:116)
at org.eclipse.linuxtools.internal.gprof.view.GmonView.displayGprofView(GmonView.java:252)
at org.eclipse.linuxtools.internal.gprof.action.OpenGmonAction.open(OpenGmonAction.java:52)
Any help appreciated
Bhushan
  • Attachment: gmon.zip
    (Size: 1.62KB, Downloaded 52 times)
  • Attachment: samples.png
    (Size: 197.94KB, Downloaded 34 times)
Re: gmon.out generated on target board is failing due to EOF Exception while visualizing in Eclipse [message #1817829 is a reply to message #1817782] Fri, 29 November 2019 20:12 Go to previous messageGo to next message
Jeff Johnston is currently offline Jeff JohnstonFriend
Please open a bug at bugs.eclipse.org against Tools Linux Tools gprof. In the bug, please refer to the level of Eclipse you are using and gcc version.
Re: gmon.out generated on target board is failing due to EOF Exception while visualizing in Eclipse [message #1817833 is a reply to message #1817829] Sat, 30 November 2019 06:21 Go to previous message
Thank you
Previous Topic:Linux Tools 7.1.0 is released for Eclipse 2018-12
Next Topic:Valgrind on Eclipse 4.9 Error
Current Time: Thu Dec 09 12:54:53 GMT 2021
Powered by FUDForum. Page generated in 4.18257 seconds
