Home » Eclipse Projects » NatTable » FormulaGrid
FormulaGrid [message #1817681] Wed, 27 November 2019 14:42 Go to next message
We have a table with Two Column : Column A, Column B
Column A -> Is Not Editable
Column B -> Is Editable
Now If we make all cell editable then only "Copy/Series"is working . But if Col A is not editable and Col B is editable , then "Copy/Series" menu is showing . But clicking on it has no effect.
we are using below code:
natTable.addConfiguration(new FillHandleConfiguration(bodyLayer.getSelectionLayer()));
// This is the formula specific configuration
new MyDefaultFormulaConfiguration(
bodyLayer.getFormulaDataProvider(),
bodyLayer.getSelectionLayer(),
natTable.getInternalCellClipboard()));
bodyLayer.getFormulaDataProvider().setErrorReporter(new FormulaTooltipErrorReporter(natTable, bodyLayer.getDataLayer()));
this.natTable.configure();
natTable.doCommand(new EnableFormulaEvaluationCommand());
In MyDefaultFormulaConfiguration ,:
Instead of All column Editable , we are making editable only Column B. Column A is not editable, The Cell Fill "Copy/Series" is showing , but not working:
public void configureRegistry(IConfigRegistry configRegistry)
configRegistry.registerConfigAttribute(
EditConfigAttributes.CELL_EDITABLE_RULE,
IEditableRule.ALWAYS_EDITABLE,COLUMN_B_LABEL);
If we make all cell editable , then only its working.:
IEditableRule.ALWAYS_EDITABLE);
Re: FormulaGrid [message #1817684 is a reply to message #1817681] Wed, 27 November 2019 15:14 Go to previous messageGo to next message
It is not working when you are doing what? In the not editable column it can of course not work.
Re: FormulaGrid [message #1817698 is a reply to message #1817684] Wed, 27 November 2019 22:20 Go to previous messageGo to next message
Coumn A is not Editable and Column B is always Editable. Now if Column A is not Editable, In Column B , Copy/Series not working . Copy/Series Popup menu is showing , but clicking on it not does nothing.) . IF Both Column A and Column B is editable then only Its working. I need , that FillHandler(Copy/Series will work for a particular editable column , while other column are in non-editable mode.
Re: FormulaGrid [message #1817703 is a reply to message #1817698] Wed, 27 November 2019 23:19 Go to previous message
With the given information I can't help.
a) The fill handle stuff is not related to formula handling. It is just placed in the formula example.
b) You can debug in FillHandlePasteCommandHandler to see what happens and why the update is not applied.
Previous Topic:background image not showing in column header
Next Topic:Validation error style
Current Time: Thu Jun 12 15:43:17 EDT 2025
Powered by FUDForum. Page generated in 0.05608 seconds
