Re: How to unit test diagram related operations ? [message #1818037 is a reply to message #1817585] |
Wed, 04 December 2019 15:01 |
Mehdi Belatrous Messages: 6 Registered: September 2019 |
Hello Florian and thank you for your indications. However digging through Capella Test Suite just got me even more confused. For example I see that the common testing pattern seems to create some test cases which extend the BasicTestCase class, register these cases in some test suites, all this inside an Eclipse Plugin. I suppose that these suites are called using an Eclipse Application Run/Debug configuration which loads a Capella instance. So my question is :
Did I did get this right and is this structure mandatory ? (TestCase + TestSuite + Eclipse Plugin + Eclipse Application). Because for non-diagram operation I could run my test using JUnit debug configurations.
Should all tests be in a dedicated plugin containing a "model" folder with .aird and .melodymeller files ?
Thanks for your help.
[Updated on: Wed, 04 December 2019 15:05] Report message to a moderator
FUDForum. Page generated in 0.02645 seconds
