[CDO] Repository checkouts not visible in Project Explorer [message #1817172] |
Sun, 17 November 2019 20:19 |
Christoph Mack Messages: 4 Registered: November 2019 |
I am trying to get started with CDO and encountered a problem using checkouts. I am using a remote CDO model repository created following the tutorial at https://wiki.eclipse.org/Getting_started_with_CDO_Helios. Creating sessions and transactions via the 'CDO Sessions' view and concurrently modifying models as described there works fine.
The creation of checkouts, via the checkout wizard opened via the 'Project Explorer' view, and the 'CDO Repositories' view's 'Checkout' and 'Checkout as...' actions, also seems to work, as there are no error messages or, as far as I can tell, exceptions thrown when trying to create a checkout.
Also, the created checkouts appear on the file system, e.g. under ${workspace_loc}/../runtime-EclipseApplication-client-2/.metadata/.plugins/org.eclipse.emf.cdo.explorer/co/9/checkout.properties:
#OnlineCDOCheckoutcheckout.properties
#Sun Nov 17 19:57:23 CET 2019
timeStamp=0
branchID=0
branchPath=MAIN
rootID=U_uO70gAlrEeqZTIJCXBPf-g
readOnly=false
label=Online Transactional Checkout (7)
type=online-transactional
repository=2
However, none of the created checkouts appear in the client's 'Project Explorer' view. The Project Explorer only ever shows "There are no projects in your workspace. To Add a project: Create a project... Import projects...".
Working with a newly created client-local repository created via the 'CDO Repositories' view, instead of the remote repository created in the tutorial, makes no difference. It also doesn't matter whether an online transactional, an online historical or an offline checkout is created.
I followed the tutorial using the current version of Eclipse Modeling Tools (2019-09 R (4.13.0), build 20190917-1200). The generated RCP client application uses Eclipse Platform (2019-09 (4.13), build I20190916-1045).
I am relatively new to Eclipse so the problem might have to do with some Eclipse setting I don't know.
I have, however, deactivated all filters for the Project Explorer and selected the 'CDO Checkouts' extension under 'Filters and Customization'/'Content'. Restarting the client application didn't make a difference.
FUDForum. Page generated in 0.03196 seconds
