Home » Language IDEs » AJDT » An automatic Eclipse update erased all my projects
An automatic Eclipse update erased all my projects [message #1817019] Thu, 14 November 2019 07:59
buddy jewgah is currently offline buddy jewgahFriend
I cannot find my project files and I'm afraid that an unwanted automatic update of the IDE Eclipse erased them all,
This is my .log file
My projects folders were on the folder "Java Projects" on my desktop.
Edit: There is no such folder c:/users/jorda/git
Do you know what happened ?
here is my lof file:
eclipse.buildId=4.13.0.I20190916-1045
java.version=1.8.0_231
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=fr_FR
Framework arguments:  -product org.eclipse.epp.package.java.product
Command-line arguments:  -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.java.product
!ENTRY org.eclipse.egit.ui 2 0 2019-11-13 15:15:09.303
!MESSAGE Warning: The environment variable HOME is not set. The following directory will be used to store the Git
user global configuration and to define the default location to store repositories: 'C:\Users\jorda'. If this is
not correct please set the HOME environment variable and restart Eclipse. Otherwise Git for Windows and
EGit might behave differently since they see different configuration options.
This warning can be switched off on the Team > Git > Confirmations and Warnings preference page.
!ENTRY org.eclipse.ui.ide 4 0 2019-11-13 15:17:34.999
!MESSAGE Could not import project located at C:\Users\jorda\Desktop\Java Projects
!STACK 0
org.eclipse.ui.internal.wizards.datatransfer.CouldNotImportProjectException: Could not import project located at C:\Users\jorda\Desktop\Java Projects
    at org.eclipse.ui.internal.wizards.datatransfer.SmartImportJob.toExistingOrNewProject(SmartImportJob.java:565)
    at org.eclipse.ui.internal.wizards.datatransfer.SmartImportJob.run(SmartImportJob.java:252)
    at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63)
Caused by: org.eclipse.core.internal.resources.ResourceException: Invalid project description.
    at org.eclipse.core.internal.resources.Project.checkDescription(Project.java:173)
    at org.eclipse.core.internal.resources.Project.assertCreateRequirements(Project.java:57)
    at org.eclipse.core.internal.resources.Project.create(Project.java:267)
    at org.eclipse.core.internal.resources.Project.create(Project.java:251)
    at org.eclipse.ui.internal.wizards.datatransfer.SmartImportJob.createOrImportProject(SmartImportJob.java:604)
    at org.eclipse.ui.internal.wizards.datatransfer.SmartImportJob.toExistingOrNewProject(SmartImportJob.java:552)
    ... 2 more
!ENTRY org.eclipse.ui.ide 4 0 2019-11-13 15:17:49.989
!STACK 0
    ... 2 more
!SESSION 2019-11-13 15:19:24.483 -----------------------------------------------
!ENTRY org.eclipse.egit.ui 2 0 2019-11-13 15:19:32.926
!SESSION 2019-11-13 15:20:45.896 -----------------------------------------------
!ENTRY org.eclipse.egit.ui 2 0 2019-11-13 15:20:54.899
!SESSION 2019-11-13 15:24:01.690 -----------------------------------------------
!ENTRY org.eclipse.egit.ui 2 0 2019-11-13 15:24:09.868
!ENTRY org.eclipse.ui.ide 4 0 2019-11-13 15:25:10.211
!MESSAGE Could not import project located at C:\Users\jorda\Desktop\Java Projects\.metadata
!STACK 0
org.eclipse.ui.internal.wizards.datatransfer.CouldNotImportProjectException: Could not import project located at C:\Users\jorda\Desktop\Java Projects\.metadata
    ... 2 more
!SESSION 2019-11-13 15:34:00.160 -----------------------------------------------
Framework arguments:  -product org.eclipse.epp.package.java.product -product org.eclipse.epp.package.java.product -product org.eclipse.epp.package.java.product
Command-line arguments:  -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.java.product -product org.eclipse.epp.package.java.product -data C:\Users\jorda\Desktop\Java Projects -product org.eclipse.epp.package.java.product
!ENTRY org.eclipse.egit.ui 2 0 2019-11-13 15:34:11.412
!SESSION 2019-11-13 15:38:04.560 -----------------------------------------------
!ENTRY org.eclipse.egit.ui 2 0 2019-11-13 15:38:13.181
!SESSION 2019-11-13 15:56:11.174 -----------------------------------------------
!ENTRY org.eclipse.egit.ui 2 0 2019-11-13 15:56:19.633
Previous Topic:'aspect' reserved word underlined as an error.
Next Topic:availability of AJDT based on Aspectj 1.9.5 with JDK13 support
Current Time: Mon Mar 30 10:39:52 GMT 2020
Powered by FUDForum. Page generated in 0.48095 seconds
